Added a 2nd ac unit (Dometic Duotherm 13,500 btu) over the weekend and found out the fan runs all the time. I understand this is how it is suppose to work. The compressor is the only thing that cycles on and off.
What Can I do to have the fan shut off when the temperature is correct? The other ac does work like one in your house. Right now it is a non ducted unit with the controls in the face plate.
Thank you for the help.
Thanks,
Mark
05 F-350 SRW Crewcab 4x4 PSD Long Bed, Torque shift with 3.73 drive, 57 gallon trans-flow fuel tank(replaced stock)
04 Sierra 32 bhbs 5er ( Sold )
09 XLR 385x12 Toy Hauler
07 40' GN triple axle Millennium Trailer
One who knows what they are doing could rewire the fan to come on with the compressor. But I don't reccommend it unless you really know what you are doing.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
If you have the AC wiring diagram and have experience with wiring and controls it should be fairly easy to wire the fan to come on only with the compressor. However, as tvman44 said, only if you know what you are doing. Also, you probably will void the warranty by doing it.
John
1988 Fleetwood Limited 37' MH
1999 F-350 PSD Super Duty 4x4 Coachmen Royal 32' TT
The wall and window units they use in hotel rooms have a little switch just inside the cover to switch the fan between cycle/continuous. Don't suppose such a switch exists in your unit. Eh
