RV.Net Open Roads Forum: Class A Motorhomes: power surge protection
 > power surge protection
ShapeShifter
Buffalo, NY
Posted: 08/15/08 05:57am Link  |  Quote  |  Print  |  Notify Moderator
fcooper wrote:
We use the hard wired Progressive 50 amp model, wired downstream of the transfer switch to also protect against generator malfunctions.
I have the same, and wired it the same way. Some will say it leaves the transfer switch vulnerable, but I'm not too worried about that. I figure it will take a pretty good hit to damage the transfer switch. I like the fact that it tells me the status of the generator, and helps protect against generator malfunctions that cause the wrong voltage or frequency. I figure that's more likely than the transfer switch being damaged.
The progressive has saved me from low voltage half a dozen times in the last year, and also protected me from a 20 amp outlet that had hot/neutral reversed. These are the kind of situations that are more common than surges. Make sure that anything you consider protects against the common voltage and wiring problems, not all of the cheapest ones do.
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
Badeye
Bonaire GA
Posted: 08/15/08 07:27am Link  |  Quote  |  Print  |  Notify Moderator
I have the Progressive portable 50 amp model. Has saved me from low voltage and surges several times.
Badeye
"No one can guarantee success, only effort."
Bob & Fran
2005 Coachmen Sportscoach Elite 40 ft DP
2003 PT Cruiser
Featherlite Car Hauler
FMCA F324606
