RV.Net Open Roads Forum: Tech Issues: Hole in Battery
 > Hole in Battery
Fleet Man
Western WA
Posted: 08/14/08 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Like TEXAS suggested, find a battery dealer, not a parts store retailer. If the plates are not damaged, the case can be repaired and the battery acid can be replaced. Also, do a good job of cleaning up everything the spilled acid touched.
2007 Winnebago Journey 34H
Toad, '08 Ford Taurus X
Blue OX, Aventa
US Gear UBS
john b
anywhere USA!
Posted: 08/14/08 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
I saw a battery repaired with Tiger Hair a body filler and it held!
If you have a battery builder near you they could repair or recase it also!
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2004 Crossroads Paradise Point PF33Rl 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
96Bounder30E
Birthplace of the Boysenberry, Orange County, CA
Posted: 08/14/08 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
One time I repaired a hole in about a week old truck battery.......I used super glue.....Cyanoacrylate..........and fiberglass filler.....or "Micro balloons".............made a paste out of it and spread it with a popsicle stick......I didn't have much money back then to go buy more battery acid, so I used a glass turkey baster and removed a little bit of acid from each of the other good cells and put it in the fixed cell........I then filled each cell up with distilled water and put it back in the truck......
That truck was sold several years later with that same battery!
hershey
Albuquerque,(fulltime) NM, USA
Posted: 08/14/08 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
I'd try a good epoxy to seal the hole if your not in a position where you need the battery right away. Obviously clean it good and sand the area around it to get a good adhesion.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
Hamops
Oshawa, ON, CA
Posted: 08/14/08 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry to read about your misfortune, but in all likelihood, the plates in the damaged cell are toast. Once the electrolyte leaked out, they were exposed to air. The air will oxidized the plates very quickly. Once that's done, the plates are only good for recycling. You can try the suggestions that were put forth in this thread but I doubt if you'll be able to savage the battery.
Helen & George VE3INB and Max (Bichon Frise)
06 Silverado LT 2500HD D/A
2006 Crossroads Cruiser CF30SK
Prodigy Brake Controller
16K Reese Slider with
a Bedsaver
g1g
ohio
Posted: 08/14/08 11:59pm Link  |  Quote  |  Print  |  Notify Moderator
It can still be good. Same thing happened to me. I droped a brand new battery in the holder and there was a bolt sticking up, went right thrugh the case. I cleaned the bottom and side edges then sanded it a little with course sandpaper. Then I mixed up some body filler on a piece of wood the same size as the base of the battery and spread the filler out on the wood. Take the battery and set it on pushing it a little so it seals good. Don't try to push out all the body filler though. It has been many years since I did that and my guess is that I had about a quarter or third of an inch of filler plus the wood. I never had a problem with the battery since.
Wherever I happen to park
Posted: 08/15/08 09:50am Link  |  Quote  |  Print  |  Notify Moderator
I have fixed a battery by applying epoxy the problem is that the liquid is NOT WATER but acid, you need to re-fill the cell with the proper strength of battery acid (Same as what's in the remaining cells) This is not an easy task. for the non-chemist.. In fact I'm not sure I'd want to try it and I majored in science and math (The skills needed)
JayflightG2
Vancouver
Posted: 08/15/08 10:01am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for al the input guys. I may just pick up another one due to the fact the other 3 I have are all pretty new anyways
BTW - For those of you who asked - I was out camping and had some pretty hard rain and water got into the battery holder. I thought I would make a small hole in the bottom to drain the water out with my drill. Well, I guess I pushed a bit hard and went right through the battery case. I did not notice until after I got home. The TT had been plugged into shore power for at least 2 weeks cooking the plates of the empty cell and I will assume that the cell is DEAD
Off to the battery shop I go......
2008 F350 Super Crew Lariat PSD
2008 Jayco Jayflight G2 29FBS
1200 lb Draw-Tite Trunnion WDH/DC
Retired_nuke_ET
Carrollton Va.
Posted: 08/15/08 11:13am Link  |  Quote  |  Print  |  Notify Moderator
I heard that's one way to silence an annoying neighbors auto alarm.
bucky
Eastern Shore of MD
Posted: 08/16/08 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
JayflightG2, we've all done similar things. The prize however, goes to the State Police tech some years back who used over long screws to attach the trunk mounted radio gear that they used at the time. We sold them a LOT of gas tanks. (This was not the MSP by the way.)
99 F250 PSD CC LB 3.73 4X4 7360 lbs, and it can sink in the mud FAST, 2004 Coachmen Catalina TT 297RKS 8200 lbs on the road.
 > Hole in Battery
