RV.Net Open Roads Forum: Tow Vehicles: My first beef with the dodge ram
Search only in Tow Vehicles
 > My first beef with the dodge ram
SkiDood
Peoples Republic of Minnesota
Posted: 08/14/08 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
What a STUPID place to have a female grease zirk, on the cardan joint. After an hour with 3 different styles of needles, and a huge mess of grease and none in the dang joint I'm saying to heck with it. When the joint fails I'll replace it, at this point its worth it to me. ARGGGG.
Any one else feel my pain?
Late model wife
2002 Daughter
2005 Daughter
2007 Ram 3500srw 5.9L Cummins Laramie. QC Short bed.
2008 Crossroads Zinger 30RB 5th wheel.
18k Reese signature series slide hitch
Rollincool
Always Rollin
Posted: 08/14/08 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Try taking an old end from a GG, and grind it down where it will sneak in between the joint. Worked for me with some tight zerks.
Either that, or pull the 4 bolts, drop the shaft so you can bend the joint real good to open it for clearance.
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6340DK
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - KLTH - K•HiTS 106.7
BenK
SF BayArea
Posted: 08/14/08 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Check out this link on the topic: http://www.woodalls.com/cforum/index.cfm........d/21403815/gotomsg/21404206.cfm#21404206
-Ben Picture of my rig
SkiDood
Posted: 08/14/08 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Got the dang thing. Finally got the right bend in NAPA part #715-1213, 4" u-joint gg adapter. God help me if I ever lose my "custom" tool.
YnotTurbo
Alpharetta Georgia
Posted: 08/14/08 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Oops, I have not been greasing the joint. I have only been greasing the tie rod ends. Guess I will have to get to it. Glad you posted this. I have 20K on my truck and pretty sure the dealer has not done this ever as well.
Navy Chief
2007 Dodge Ram 3500 Laramie w/6.7 CTD, 6 speed auto, Factory Exhaust Brake.
2007 KZ 41CKS3 Montego Bay Sportster
2006 Kaw KDX 200
2008 Can AM Outlander Max 650
2006 Yam R6
2007 Suz GSXR 600
Golf cart
Real Trucks Don't have Sparkplugs!
ib516
Up here!
Posted: 08/14/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
I tried yesterday....for an hour. Dang shoulder is sore, and I'm sure there's still no grease in there!!!!
2004 Cougar 301 BHS 6580# Dry, 9000# wet, 9600# GVWR)
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
Hypertech Max Energy
"MEGACASPER" 10100# GVWR, 5200# FGAWR, 6200# RGAWR
PICTURES
ELIM 3000 Gen (still going)
Collision Reconstructionist
ScanGauge2
JustLabs
Washington State
Posted: 08/14/08 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
I'd be willing to bet your dealer doesn't even know its there.
Or if they do know its there,they'll say it actually doesn't exist.
2007 Dodge Ram 3500 SRW,4x4,Cummins 5.9, 6spd.
2007 Keystone Cougar 289BHS Fifth Wheel.
Ductape
On the Road
Posted: 08/14/08 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
One trick I use is to jack up one front wheel so I can rotate the shaft freely to just where I want it. Those cardans are a pain in the rear for sure.
Surveyor SV-234 >Equalizer> H3
Previously a fiver crew.
mowermech
Billings, MT
Posted: 08/15/08 06:35am Link  |  Quote  |  Print  |  Notify Moderator
Let's see, I think the first time I encountered one of those (unspeakable, unprintable) things was on a Chevy 4X4, many years ago. It ultimately failed, and a friend who had a home machine shop made a new shaft for me WITHOUT that joint. Other than a slight vibration above 70 MPH, no problem.
I feel your pain. The engineers really created a winner, there!
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, Std. cab, LB, 5 speed, 4.10 LS diff., Jacobs Rambrake, 273,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '06 Jeep Liberty CRD
Towed: '06 Jeep Rubicon Unlimited
rsh_757
Auburn, WA
Posted: 08/15/08 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Driveshafts come out so easy anyways.. But I haven't greased mine in 50k, I doubt my dealer has either. Life goes on.
2008 Cougar 310SRX 5th Wheel
2005 Dodge Ram 2500 QC 4x4 CTD
2008 Nissan Armada LE
