jparker66
Rockwall, Texas
I have a 2 year old HR Savoy SL. When I was washing the roof last weekend, I noticed the caulking badly cracked along the front left edge. I have some wide tape like caulking but it does not stick well. What do most of you do?
Thanks for the input.
James
James & Sharon
2006 Holiday Rambler Savoy SL 29'
2004 Dodge Quad Cab Hemi
CAMPING IS GREAT! ENJOY THE OUTDOORS!
Gale Hawkins
Murray, KY
Ours is much older and we decided to just skip doing it over and over so went the Eternabond route. It is to last 17 - 35 years.
edited 08/14/08 07:19pm by Gale Hawkins *
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Fix it right the first time and the last time with ETERNABOND
rjf7g
Virginia
Seams = Eternabond
Seal around the edges of things = DAP self-leveling lap sealant
1992 Fleetwood Tioga Montara Special 27 Class C
2007 Gulfstream Innsbruck 36FRS Park Trailer
mrradio
Jamestown, ND
I'd be curious to hear more about eternabond, how it works and how easy it is for a layman to apply.
wayne_tw
South Dakota/Georgia
rjf7g wrote: Seams = Eternabond
Only use Dicor on any area associated with the roof.
sweethome alabama
Scottsboro, Alabama
I just installed eternabond on my trailer I had a bad spot and had to do repair and the seams are now eternabond. I plan on doing my vent,fridge and skylight before I call completed. I used roofseal one step for 51.00 at rvupgrades for a 4inch wide by 50ft roll. I'm going to finish around edges with dicor lap sealant. Mike
SEE
edited 08/14/08 08:09pm by sweethome alabama *
04 suburban 1500
00 silverado 1500
05 jayco 27bh
Couldn't get rig to post,so here is my burgler alarm!!
CaLBaR
Ontario, Canada
I used Eternabond on all the seams and it works great.
Just wondering if anyone used it on the TV antenna and the tank vents. Screws on the TV Antenna mount are pretty close to the rotating part of the antenna. Just wondering how you did this as I think I will have trouble getting the eternabond to seal properly around the screw heads. Did think about removing the screws and putting them back in after the eternabond is stuck down.
Any suggestions?
2007 Rockwood 8298 SS
2006 GMC Sierra Crew Cab 5.3 V8 3.42
Draw-tite Max-E-Loader Hitch
HP Dual Cam Sway Control
Prodigy Brake Controller
Hornet28BHDS
Parker, PA
Stick some Eternabond to it and call it done!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
JIMNLIN
Big Cabin, OK
Dicor is another good product for just resealing on the roof. If you use Eternabond with the material backing I wouldn't lay the backing over screw heads as you may be the tech/person that has to get to the screw heads later on if a repair is needed.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
