RV.Net Open Roads Forum: Toy Haulers: Hooking up the 5th
Search only in Toy Haulers
 > Hooking up the 5th
lincster
Mesa Az
Posted: 08/15/08 07:31am Link  |  Quote  |  Print  |  Notify Moderator
msredneck84 wrote:
I always leave enough gap that I can see daylight thru. This is the way I was taught and it works for me.
Same here. I leave a little gap till I can see I am backed up far enough. Then get out and lower the trailer until it touches the 5er hitch, close and lock the jaws and then lower the rest of the way.
My wheels are always chocked until the jaws are locked, then I take the chocks out.
After the jaws are locked, I also put the truck in neutral and let everything even out before I run the jacks the rest of the way up.
Once the jacks are off the ground, before I put them all the way up, I put the truck in drive and gas it a little bit. If the trailer is going to come off the truck, I would rather have it land on the legs instead of the bed.
2006 F350 PSD CC 4X4 Dually w/Tow Boss package to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
BB_TX
McKinney, Texas
Posted: 08/15/08 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Hadn't thought of it as "making the truck squat" but that is what I do. I have the pin box very slightly lower than the hitch, maybe an inch or less. As I back up the pin box rides up onto the hitch causing the truck to "squat". That assures that the king pin moves into the hitch properly, or as mentioned no high pinning. And yes, I do not remove the chocks until I am locked and pull tested.
Ran
Wisconsin
Posted: 08/15/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Trailer Trash 2 wrote:
WHEN YOU SQUAT YOU HOOK UP, you better have that 5er chocked good, or it can roll back off the table, and bend you front legs when it comes down and they connect with the ground.
I usually will connect with it almost even but a slight pressure so I have a tight closing of the jaws to the pin.
I agree with Don.
nayther
Burbank, CA
Posted: 08/15/08 09:18am Link  |  Quote  |  Print  |  Notify Moderator
That's my method.
DIRT BIKES RULE
'05 Duramax CC short bed
'06 3005 Rage'n Falcon
Y-Guy
Tri-Cities, WA
Posted: 08/15/08 09:27am Link  |  Quote  |  Print  |  Notify Moderator
One step to save your trailer, hook up the brake control wire and the break away cord, as you start to back up reach down and use the lever on your brake controller to fully engage the brakes to prevent it from rolling. Yes chocks are good, but not fool proof.
Forced Family Fun... They'll thank you later for it!
Have you checked out the new RV.net Blogs?
gestanton
Rotterdam, NY
Posted: 08/15/08 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Always make it squat to avoid the possibility of "high hitching".
George Stanton
  • Anticipating retirement
  • Full-Timer wannabe
  • Camping with DW of 40 years and three Therapy Dogs (SmallDog, Oliver & Ted)
mapguy
Puget Sound
Posted: 08/15/08 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Yep
Billyayle
Chandler Arizona
Posted: 08/15/08 11:20am Link  |  Quote  |  Print  |  Notify Moderator
I always do the squat method. About 2-3 inches, with the wheels blocked you can give a good thump when hitching. I have a Reese and never had an issue with it hooking up this way.
Although I will say that if your hitch is too far down you can easily make your slip ring into a usless piece of plastic. I could pinch and bend the inner tabs that hold it in place. I know now to make the extra trip to the landing gear button and lift it one more time.
I don't know who posted it, but the best thing I saw was to set the level that you're comfortable hitching and then adjust (MOD) the breakaway cable to the same height so the end loop just touches the ground. That way you know how high to jack it up everytime.
2005 Dodge 3500 Crew Cab 4x4 LB SRW PacBrake
2008 Cougar 310SRX 5th
YZ400 with tweaks :-)
Kaw. 220 quad
r1Mk
modesto, ca
Posted: 08/15/08 11:57am Link  |  Quote  |  Print  |  Notify Moderator
I have destroyed several lube plates by squatting the truck. Now I adjust the height to show a little daylight. After I hook up it's pretty easy to see if the jaws of the hitch are above the bottom of the kingpin.
'06 GMC 2500HD D/A 4X4
'07 Crossforce 33MK
Winter Arctic Cat 900 1M, Polaris 700 RMK, Polaris 550 RMK
Summer Honda 300 EX, Yamaha 80, Polaris 50
CrazyTed
Hoollieville #214
Posted: 08/15/08 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
I use just a little squat, not enough to damage my lube plate.
CrazyTed
www.CrazyTed.us
Va Bch, VA
2006 KTM 450 XC
1997 Triumph Tiger 900
2005 Chevy 2500HD 4X4
2008 CrossRoads CrossTerrain TF36DS
