RV.Net Open Roads Forum: Class A Motorhomes: ABS Light
 > ABS Light
holidayal
tampa florida
Posted: 08/14/08 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
ABS Light stays on again, I have an 01 HR Admiral (Work Horse Chassis) I purchase Mar 07 the day I drove it home, the ABS light came on. until I took it to Bill Heard Chevy Plant City, Fla.they replace Bosch brake caliper and piston boot, also ABS sensor, which cost 680.00 dollars I did not have to pay for that because it was recall, However it came on again, this time noboby seems no about the recall,I need help.
Thanks Holiday Al
DrScud
On the Road
Posted: 08/14/08 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
Could be just a sensor out of alignment. Do you have the ability to check your error codes on the ABS box?
Jim & Sim - Fulltiming. - - Follow our adventures at: JimandSim.com
98 Foretravel U320 40', Cummins 450 HP/1450 lb-ft, HD4060 Allison, w/rtrder
2000 Jeep Grand Cherokee Laredo / M & G Braking / Demco Excali-Bar
Current location
jgolden
NY USA
Posted: 08/15/08 07:39am Link  |  Quote  |  Print  |  Notify Moderator
The folks who first repaired it are saying they don't know what the problem is?
1990 Allegro 30ft Diesel Puller 5.9 Cummins, 2004 Malibu Max Toad
JaBob
Roswell, Georgia
Posted: 08/15/08 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the club. I have the same problem. An interesting twist. Are you towing? I've been told by my mechanic the light is a result from towning without a brake system. I've added a Brake Buddy and guess what. The light doesn't come on! Estimated cost to replace sensors was $700.
Bob
Wherever I happen to park
Posted: 08/15/08 10:48am Link  |  Quote  |  Print  |  Notify Moderator
I had an ABS issue too, plus my cruise control refused to control
Brake light switch
There are several other issues, some of which are discussed above, that can cause the same symptoms. Several are discussed above
ConnieP
Wallkill, NY
Posted: 08/16/08 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
We have the Workhorse chassis also. Our ABS light comes on at times and we cannot figure out what the problem is. This problem occurs whether we are towing or not. We also use a Brake Buddy for what it's worth but it hasn't helped.
catkins
Washington
Posted: 08/16/08 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
Had the same issue with a brand new Workhorse chasis. After four trips in, had sensor replaced after loose WHEELS were considered the first culprit.(Yeah, I felt safe.........not!!!) Was an intermittment issue and not pleasant to cope with. Reading the manual reassured me I had brakes but not ABS function when the light would come on. Replacement fix seems to have done it. Finding the exact problem seems to be a challenge. Good luck and be safe!
rob98801
North Central Washington State, USA
Posted: 08/17/08 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
my ABS/check brake lamp drove me nuts. Did all the checks,and had a complete rebuild of the brake system. Was fine for a while then the lamp would come on again. After much todo the trouble was traced to High resistance grounds at the brake control unit/computer. Cleaned the grounds and no more trouble.
1999 Georgetown M-265
568th SMS 381st MIMS
 > ABS Light
