chugalong
SanAntonio Texas
just wondering if I have the break away cable hooked up the right way. It is threaded in the links of one of the safety chains and hooked to the last link before the hook that hooks to the hitch. It looks like it would only work if the safety chain stayed hooked to the truck and the other end broke free from the trailer. Is this right?
Also just wondering if while at a rv park if any one puts a lock on the tongue of their trailer so it doesn't get stolen while you go off to the Piggly Wiggly.
Quick trip
Cerritos, Ca.
You are right on hooking it into the chain as the other end should pull out of the break-away-switch.
When I had 2 different TT's I always put a lock on the ball or tongue right after hooking up.
Now with the fiver I still put locks on things to keep them from walking away.
Good Luck & drive Safe!
chugalong
SanAntonio Texas
Thanks Quick Trip
Mike Schriber
San Diego, CA
The routing if your breakaway cable is not correct. It should not be run through the chains. In fact, the end of the cable should ideally attach to a point on the tow vehicle that is not connected to the hitch or receiver.
Mike
2005 Chevrolet Suburban K2500 LT (8.1 liter with 4.10 gears)
2004 Starcraft Homestead 29BHS (16,000 pounds combined)
Twin Honda EU2000i Generators - 12' Porta-Bote
Prodigy / Putnam XDR / Equal-i-zer
SoCal Family Campers
LarryJM
NoVa
Mike Schriber wrote: The routing if your breakaway cable is not correct. It should not be run through the chains. In fact, the end of the cable should ideally attach to a point on the tow vehicle that is not connected to the hitch or receiver.
Mike
Correct answer, now to how long it should be
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
Bigburd
Tennessee
Mine is long, I run it thru both chains to take up the slack then attach it to a connection on my frame seperate from the hitch.
07' Ford F-250 SD 6.0L
08' Keystone Sprinter 250 RBS
beemerphile1
NE Ohio
Mike
Correct answer above!
Take it out of the chain. Attach it to the tow vehicle, and not to the hitch or receiver. The length should be such that it will pull the pin while the safety chains are still connected.
Tim
"Okay, I admit it, the only thing I'm really good at is being me."
Support the "No Child Left Inside Act"
2006 Weekend Warrior FK1900
1998 Ford E150 4.6L
1996 BMW R1100GS
2005 Trek Madone 9spd.
1995 Burley tandem
Lucky Mr H
Creston, IA
Definitely attach the break away to the TV and not anything on the hitch or receiver. The cable should be long enough to make the attachment and still be able to flex with all the stretch when turning.
dodge guy
Chicago, western subs.
How are your safety chains attached?
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
chugalong
SanAntonio Texas
dodge guy wrote: How are your safety chains attached?
mine are bolted to the tongue then crisscrossed and hooked to the hitch.
Phil
