RV.Net Open Roads Forum: Beginning RVing: break away cable
 > break away cable
rolnrolnroln
WA
Posted: 08/19/08 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Surprise! Nobody who tows with a PullRite TT hitch can ever attach the breakaway cable anywhere but the hitch. The ballmount can travel completely from one side of the truck to the other while in operation. No fixed point on the TV can ever be used for chains or breakaway cable.
Mousefart
New Jersey
Posted: 08/19/08 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
Hah! Take that you "you can't hook your breakaway cable to the hitch" people! Let's see you counter THAT one!!! (I "blowing rasberries" in your general direction!) <--- copyright: Monty Python
Paul (Mouse)
2007 Flagstaff Shamrock 17 Hybrid (heavily modified for boondocking and winter camping).
2007 Dodge Dakota Quad Cab 4x4, 4.7L HO, factory tow, 3.92 gears.
Equil-i-zer Hitch, Prodigy.
Yamaha EF2400 Generator (quiet, cause I care!)
Campinfan
Washtenaw County, Michigan
Posted: 08/19/08 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know anyone who had their trailer come off the hitch and had the the safety chains or the brake cable come into play? Just wondering?????
BTW there is an effect in crash reconstruction where the phrase "locked wheels lead". If you lock the rear wheels up it want to rotate to the front (hence "donuts"). I would not want to have my trailer brakes lock if the hitch failed but the chains held.
________
2008 F 250 FX4 4WD, V10, 4.10 Tow Command
35' 2007 Crossroads Cruiser CT32SB
Wonderful Wife and 3 small kids
Campinfan
Posted: 08/19/08 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Great line from Monty Python but I will type the word they used...fart.
dodge guy
Chicago, western subs.
Posted: 08/19/08 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
I believe you can extend the cable and attach it to the underside of the TV where the hitch attaches. kinda like how you would have to attach the 7-way wiring.
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
wittmeba
Roanoke, Va
Posted: 08/20/08 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Mousefarts,
This pic:
http://members.cox.net/bruce.wittmeier/images/F1DAEE7Ed01.jpg
Hope he isnt hanging by his breakaway cable!!
* This post was edited 08/20/08 03:30pm by wittmeba *
Bruce & Carolyn Wittmeier
Viet Nam Vet 1968-69
I was born in Great Falls, Mt. My parents moved when I was 5.
I found them when I was 10 - they were in California.
beemerphile1
NE Ohio
Posted: 08/20/08 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
I have heard of the hitch but am not familar with it. How and where does the seven wire power cable attach that the breakaway cable cannot? Isn't the power cable at some fixed point on the tow vehicle?
Tim
"Okay, I admit it, the only thing I'm really good at is being me."
Support the "No Child Left Inside Act"
2006 Weekend Warrior FK1900
1998 Ford E150 4.6L
1996 BMW R1100GS
2005 Trek Madone 9spd.
1995 Burley tandem
LarryJM
NoVa
Posted: 08/20/08 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
I might be wrong, but from the pics I've seen the safety chains and also the 7 pin connector along with the breakaway cable are all attached to what we would consider our receiver. The pullrite has an arm attached close to the rear axle that is supported on a track and that arm might not be considered a receiver as such, but an extension of the TV itself and thus attaching those item to that is an exception to most of our common ideas of where to attach things. I'm sure pull-rite went thru some sort of certification of their hitch to meet all the various state requirements and obviously they have so this "RED HERRING" is just that in this somewhat unique case configuration.
BOTTOM LINE is to hook it up per the manufacturer's directions.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
K3WE
Missouri
Posted: 08/20/08 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
1) Yeah, had a small trailer come unhitched and whip pretty wildly, but safety chains held and I slowly came to a stop, rehooked the trailer and modified the latch so it would not happen again. No trailer brakes nor breakway cable in this case.
2) I think "locked wheels lead" does not really apply in the case of the trailer. Absolutely, I can lock the rear wheels of my car and it will try to make the rear lead, and if a semi locks the drive wheels, they tend to become the lead wheels, but I'm not seeing the physics that's going to make the trailer pass you if the trailer locks down and takes the slack out of your chains.
3) Sadly, I'm sure there's been more than one case of a dead or unhooked trailer battery or the breakawy not hooked up, and the trailer goes off and does it's own thing and kills someone.
92DakotaHD
Indiana
Posted: 08/20/08 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
I hook mine to the hitch pin and use the fastening pin on it to lock it on. It's not the frame but I'm short on things to hook to on the Tahoe. But I don't have it hooked to the shank. MIne is run through the chain links.
1992 Dakota 2WD 5.9L V8 (NOT Stock)
Headers, FMS Injectors, Ported TB, MP PCM (not good for towing),
2005 Chevy Tahoe Z71- Bermuda Blue, A/T Revo 265/70 "E"
Prodigy Controller
08 Passport 24RB, YAY SPACE!
Gone Racing!
A newbie, any tips please share!
 > break away cable
