RV.Net Open Roads Forum: Truck Campers: Truck bed
 > Truck bed
Raften
Northern Calfornia
Posted: 08/15/08 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have found the best use for a bd liner if you have a TC is to use it in the back yard. The make great firewood covers.
jsmmv
California
Posted: 08/15/08 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Falcongunner wrote:
Can one use a rubber mat on top of the bed liner or is the problem still the same?
Wayne in North Texas
When I got my new to me truck I did just that and also put a rubber mat under the liner,I have gone many miles without a problem but it makes it more difficult to load the camper as your clearances are less.
I am going to remove it and get a spray in liner soon.
Jeff
artfd
Ohio
Posted: 08/15/08 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Have a 1983 F250HD long bed with a slick rigid plastic bed liner carrying a 1975 Honey slide-in TC, and have been using this combo since 1999. TC clamps to underframe at 4 points using chains & turnbuckles. Absolutely no trouble with sliding or instability with this system. I think the slickness of the bed liner helps in loading & unloading the TC.
How did this ever get to be an issue?
Adam3
Here
Posted: 08/15/08 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
I've had this truck and a TC for coming up on 10 years. Have always had a bedliner and have NEVER had a problem with shifting, loading, unloading, etc. There's a lot a great info here as well as expierence, but since it sounds like you've already got the bedliner installed give it a whirl and see how you like it. If you don't, take it out and put a mat down. Sorry you asked?
Raften
Northern Calfornia
Posted: 08/15/08 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
How does slickness of the bed liner help loading and unloading. It must be just the area of contact on the wheel wells.
wnjj
Cornelius, Oregon
Posted: 08/15/08 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe if the front bumpers are too close it will slip backward a bit when it drops in?
JimBollman
Upstate NY
Posted: 08/15/08 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
I would not have a plastic liner, even if I didn't carry a camper. Besides the obvious slick problem, hauling anything will slide around, they retain dirt and moisture. Dirt and moisture slowly grinds the paint away then it rusts. I have seen this on several trucks including the last used one I bought.
Put me in the rubber mat camp.
Jim...
Stim
NE Florida
Posted: 08/15/08 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
My bedliner fits very well and stays put. It has the Chevy Bowtie logo on the front and has 1/2-3/4" ribs all the way accross. I don't have problems with stuff sliding around.
I did know a lady that Armour-All'ed her bedliner and WHAT A MISTAKE!!
 > Truck bed
