RV.Net Open Roads Forum: Fifth-Wheels: Removable 5er hitch pins
 > Removable 5er hitch pins
Lucky Mr H
Creston, IA
Posted: 08/15/08 10:34am Link  |  Quote  |  Print  |  Notify Moderator
I haven't really seen this in the forum, yet....
I have a Reese removable 5th wheel hitch that stays in the truck 90% of the time.
Whenever I want to remove it, I know I'd better take my ball peen hammer with me. Three of the pins come out with relative ease, but there is one, and it's always the same one, that is a pain in the rear to get out. I've examined everthing, and it looks the same as all the others.
Any ideas, suggestions on how to get this improved?
4Kings
NE Missouri
Posted: 08/15/08 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Mine does the same thing. I took a small file and touched up the slot, helped a little but it's still tougher to get out than the other three.
2003 Chevrolet 2500HD, CC, SB, 6L, 4.10, Auto, 4x4
2005 Wildcat 27BHWB, RBW 15K, Prodigy, TTT Mirrors
F-TROUP
VISALIA, CALIF
Posted: 08/15/08 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
I'd leave it as no one can steal it in the middle of the night without wakeing the world.......JMHO
rscraig
Denton, TX
Posted: 08/15/08 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
If your talking about the four pins that hold the hitch to the bottom rails, mine is the same way. After experimenting, I discovered the holes wont line up exactly right until I push the hitch laterally a mm or so with a hammer tap. The pin then slides right in.
Steve
2007 Wildcat 29RLBS
2006 Dodge 2500 4x2 QC 5.9L CTD
silverthunderroad05
Seneca, SC, USA
Posted: 08/15/08 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
i have a 16k and mine is the same way......
2005 Dodge, 24 Valve, Turbo Diesel Cummins
2009 Copper Canyon Fifth Wheel, Reese Slider Hitch, Prodigy Brake Control
bdougt
Now Louisiana, Eventually Michigan
Posted: 08/15/08 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 16K and can remove all 4 without any force - just a little wiggling.
Brian, Donna, and Ted the dog.
2006 Dodge MegaCab 2500 Laramie 4x2 CTD 48RE 3.73 gears
Firestone AirBags - 16K Reese with Slider
2006 River Canyon 34KSTSO - TrailAir Pin - XPS RIBS 245/75/16
ezrider6298
Conyers, Ga. Rockdale
Ditto here---have the same hitch, one pin harder to get out than the others. I use the same hammer to tap it loose that DW sometimes uses on me to get her way.
E.C. & Sandra Walker, (aka She Who Must Be Obeyed), and Baby, the "children cat" (non-camping), 1999 Ford F250 CC 4WD Powerstroke, 29' Wildcat RLBS 5ver.
rather be travlin'
Rose Capitol of (Texas at least)
Posted: 08/15/08 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
I bought 1/2 inch pins at Tractor Supply with a handle on one end, and bought a set of matched locks that would fit through the hole on the other end.
'03 Dodge/HO Cummins 3500
6 speed/3.73 dually/LWB
2000 Snowbird SE 102
'08 Goldwing GL 1800
sakelarios
Redwood City, CA
Posted: 08/17/08 12:09am Link  |  Quote  |  Print  |  Notify Moderator
Had the same problem plus hitch was sticky in the rails too. Noticed the rails were slightly off. Loosened them up and repositioned them, now both hitch and pins work nicely in the rails
coachman05
Minnesota
Posted: 08/17/08 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same hitch and I have yet to take it out but, will need to in the next month or so. How exactly does the hitch come out? It looks like there are nuts that tighten down the hitch on the pins?
2008 8244 Rockwood
2003 1500 5.3 liter Silverado
