RV.Net Open Roads Forum: Class A Motorhomes: Rear Observation System
 > Rear Observation System
revump
Las Vegas
Posted: 08/15/08 11:18am Link  |  Quote  |  Print  |  Notify Moderator
The ADTH Rear Observation System on my 2004 Allegro Open Road does not work all the time. When it first starts up, there are vertical lines on the monitor. After a period of time, everything seems to become normal with the toad coming into view on the monitor. Any ideas?
Bob
Edouard
Hudson, Quebec, Canada
Posted: 08/15/08 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
We have the identical issue with our Rear Vision system, posted here a couple of weeks ago after remove the front tv unit and cleaning and applying electical grease to all connections, and the issue continues.
Someone responding that I need to remove the rear outside camera and clean the ground there properly, should resolve the issue.
Have not had time yet to do so, but when I do I will come back to my posting with results.
Good luck with yours and hope this msg helps.
Eugene & Stella Theriault,
1999 Endeavour 34CG/V-10 (No Slides)
2005 Honda Element. Blue Ox Aladin.
FMCA 318247
