CampingMoose
Fernley, Nevada
I have a hard time getting the hitch coupler lock to go down over the ball if I'm not fairly level when I hook-up, a friend said that there may be something wrong with the ball, but it seems ok to me. I measured the diameter against another ball of the same size, and it was ok, the only differance between the two ball was that one (mine) has a larger flat spot on the top of it. At first I thought it was just new and tight, but it doesnt aeem to be getting any better....any suggestions out there?
2008 TANGO 25 RKS
1996 FORD F-350 LONG BED 460 C.I. "THE GUZZLER"
Hgarnerno1
Tyler, Texas USA
Sounds to me like your coupler is not opening all the way. Check to make sure it is wide open. Perhaps some luberication would help. I know on mine, I have to make sure the lever is pulled all the way back. Good Luck..
Howard, USN Ret
2000 Ford Excursion,V10, Limited
2003 Terry 27H. Super Slide
jplunkett
Virginia
Point on ensuring the lock is fully retracted is good. If that catches when the trailer is lowered it will wedge and the ball will not get into the coupler. On mine the ball will couple up and the lock will not drop down. This happens when the ball is pressed against the back of the coupler. I will let he TV pull forward just a tad to shift the pressure against the front of the coupler, and it will engage.
safe travels,
John & Elizabeth Plunkett
Louisa, Virginia
Rumtan
Alberta
Sometimes it gets tough to couple when the ball is at an angle. Make sure that the ball is not tilted in any direction, this impedes the coupling considerably.
2002 Palomino 22'
2002 Chev Silverado V8
Fish-O-holic
Yeldarb
Omaha, Nebraska
When the WDH is tilted sometimes the ball will be tilted and it causes a little issue with the coupler locking onto the ball. I have found that when it does I have had to go ahead and finish my hook up and add tension to the WDH bars to pull the ball closer to level. When its level and locks on you can go ahead and raise the TV with the jack and take up the rest of the linkage you might need...
Brad('67) and Valerie('68) Clements
Alyssa('95)
Samson and Toby
2008 Cherokee Grey Wolf 28BH
(NEW) 2005 Ford F350 SD Crew Cab Dually 6.8L V10
(OLD) 1999 Chevy Silverado 5.3 3.73 1500 Z71
Omaha, Nebraska
Camping Nights in 2008 - 31
Our Camping Adventures
Dwight205
Terre Haute,IN
Mine does that also,what I do after I`m on the ball is have the DW bump it in drive.It will lock in,then we remove the chalks.
Gary n Vicky
Piney Woods of Texas
I had the same problem. I agree with jplunkett. After you lower the TT coupler onto the ball, put your TV in gear pulling the ball forward in the coupler, relieving any pressure on the lock letting it close with ease.
2008 Silverado 2500HD
2009 North Trail 31BHD
1955 (Me)Retired USAF
1953 Bird Loving Wife
1995 Computer Geek Grandson
Be a leader, Be a follower, or Get Out of The Way!
"Happy North Trails"
jimdubya
Paducah, KY
Gary n Vicky wrote: I had the same problem. I agree with jplunkett. After you lower the TT coupler onto the ball, put your TV in gear pulling the ball forward in the coupler, relieving any pressure on the lock letting it close with ease.
Ditto.
2004 Silverado 2500 Crew Cab 4x4 6.0L 3.73
2006 Dutchman Tundra 26RL-DSL
dodge guy
Chicago, western subs.
jimdubya wrote: Gary n Vicky wrote: I had the same problem. I agree with jplunkett. After you lower the TT coupler onto the ball, put your TV in gear pulling the ball forward in the coupler, relieving any pressure on the lock letting it close with ease.
Ditto.
Double ditto!
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
Vader1
Manch Vegas NH
never had an issue getting coupled, just uncoupled, did not want to release due to the strain, just had to release strain then uncoupled nice & easy
Vader1 aka Jay
Wif aka Kim
Bear aka #1 pug
Chewy aka #2 pug
05 Ram 1500 Quad Cab 4x4 - Yeah it's got a HEMI
08 Crossroads Zinger 30BH
