hohenwald48
Hohenwald, TN
Put it in or on the toad. If you don't have a toad then get a tire carrier rack made to go in the hitch receiver. I'd be real surprised if you don't have a hitch.
Chris
2001 Monaco Knight
2004 Dutchmen Dorado
1999 Jeep Wrangler
100% Solar Powered Home
When seconds count, the police are only minutes away.
cltkids
Lake Park, North Carolina
Quote: Mine is mounted between the frame rails in the very back.
I had a local shop mount a bracket between the I beams at the back. It is only a unmounted tire... I have it wrapped up in a fake leather cover to protect it. The bracket drops with a large bolt. Works well. I hope I never need it.
2007 Four Winds Hurricane 34B
2007 CR-V w/ Blue Ox Aventa LX/Even Brake
2 Kids/2 Dogs
Dogcliff
Anchorage, Alaska
Thanks for all of the replies. OK, I guess I really knew that the ladder was a bad idea, but it would have been SO EASY! '02 Winn 32' underbelly WILL NOT accomidate my 19.5" spare (32" tall), either width or length wise. I was able to find a receiver mount spare carrier locally, wish the price was as good as etrailer.com, but NOT. Now all I have to do is find a wheel, or engineer a method to hang it unmounted on the carrier.
dc
JUrban
Delaware
A welder with a fair size scrap pile should be able to come up with something that will work.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
havin fun
don't know yet we are not their yet .
we put our's in the trunk of the toad. it was unmounted.i think it is to heavy for the ladder ..if you have a 4 door try the back seat.
retired
havin fun with 1999 georgie boy 3515
and the wife too .
V-10 ford
we support channel 13 hello any one OUT their ? !!
North Hampton Local Weather
david_w28
Michigan
I see lots of MH's running down the road with different things hung from the ladders. I would think that if the ladder was made to hang things from the manufacture would explain this in the manual.
Hanging something on the ladder while driving down the road I would think would not be good for the ladder, and sooner or later you are going to find damage to the ladder. I would also think it would be unsafe. What if the bouncing caused the item to fall off and hit the vehicle behind you.
I like the hitch idea or some kind of a carring rack on the back.
BobMary8101
Lake County FL for the winter
We carry two folding chairs on our ladder. These are the heavy duty chairs that CW sells. We have a hook made for the ladder that we got at CW and I use double bungie cords on the bottem to secure the chairs to the ladder after placing them on the hook. The charis never move while we are traveling so I don't think the cars behind us are in any danger.
That being said, although these chairs are fairly heavy, I think a spare tire would be heavier and less stable on the ladder. Luckily, our coach has a mounted spare hanging between the frame rails in the back. I noticed that the op found a mount that he could use if the tire is mounted on a wheel. Someone suggested that an iron working shop could fabricate something to carry the unmounted spare. I would submit that buying a wheel and having the tire mounted and balanced would make more sense and probably only cost a few dollars more.
The only blow out that I ever had damaged the wheel of the blown tire so an unmounted spare would have been worthless to us. Hope this is all for naught and the op never needs his spare.
Bob
Bob and Mary
Pace-Arrow Vision 36B
Ford V-10 36 feet
Toad: 2008 Ford Focus
FMCA F398511
Daboo
Texas Panhandle USA
My 03 adventurer has the spare under the rear..think yours should have a place to mount it...it winds down with the handle that came with the unit.
I personally believe the tire and rim is too heavy for the ladder to support..sure would hate to pull the ladder loose from the body..would be a bear to repair.
Hello from the windy Texas Panhandle
Winnebago Adventurer 33V
Served proudly 1957-1965..U.S. Air Force
MRUSA
Boca Raton, FL
http://www.rvtirecarrier.com/
Marc, Boca Raton FL
2003 Beaver Monterey 40' triple slide
Blue Ox TruCenter
Acura MDX toad
Unified Tow Brake
Pressure Pro Tire Monitor
Garmin 2610 GPS
Datastorm D3/7000
Sirius Radio
Tivo on board
wny_pat
Western NYS
david_w28 wrote: I see lots of MH's running down the road with different things hung from the ladders. I would think that if the ladder was made to hang things from the manufacture would explain this in the manual.
I like the hitch idea or some kind of a carring rack on the back. There have been lots of pictures here to confirm this. Bikes lost, chairs lost, grills lost. Tire and rim that gets away can do a awful lot of damage, especially when it hits a vehicle traveling toward it. I personally like putting it between frame rails or on a hitch receiver.
