estesbubba wrote: Does anyone have a link to a chart that gives tire inflation information based on axle load? I've had no luck searching.
Make your own.
On linear graph paper chose a spot for your tire sidewall max PSI & Pounds.
Draw a line from that maximum to zero.
You now have a graph for 'your' tire. Make the 'Y' (vertical) the
weight axis. Make the 'X' (horizontal) the PSI axis.
Mid point on weight will have the corresponding to point for PSI
Here is one I made up for a magazine article wrote on tires. Used a
spread sheet, as wanted a digital copy for emailing to the editor.
Of course you'll have to weigh your setup axle by axle, both empty
and fully loaded so you'll know where you are in reference to the
weighting per axle (divide that by 2 to get what each tire should
be seeing...assumption that the loading is even side to side).
-Ben Picture of my rig
Michelin usually has charts with there tires online. If you find your tire size in there list, and find that chart, it will/should be equal to other brands. I seem to recall that the DOT or equal is the one that made the specs, or is it oversee's, such that they do not end up in a tug o war like truck manufactures and tow ratings. Along with making sure that one 245-75-15 tire is equal except for the tech going into it in tire diam, revs per mile, tread width etc.
Marty
05 Chev CC D/A LS Dooley
3 Single axle utility trailers
What is it you're trying to accomplish that you're not already getting from your door sticker? I'm guessing you're running the stock Bridgestone Rugged Trail's? If so, looking at your setup I'd say you should run your door's max (which should be 60psi front and 70psi rear). If you're concerned about tire wear, I wouldn't worry too much. I've been running those tires for 85K miles and no matter what I do they wear very evenly. But nonethless just measure your tread depth periodically (inner, middle, and outer) to keep an eye on wear.
