RV.Net Open Roads Forum: Toy Haulers: Generator Installation
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > Generator Installation
900FE_79
TN
Posted: 08/15/08 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Fuzion 302 that does not have a generator, it came prepped for one with battery cables, remote start cable & fuel lines. I now want to put one in and am a little confused on exactly what I need to buy for the install, I am getting very little help from anyone I have asked.
My issue is, I know I need an exhaust tailpipe kit but on the spec sheet for the Onan in the accessories section it also has an exhaust tube available. I don't know if I need the tube aswell as the tailpipe kit or not. There is also an installation template accessory available. I don't know what other accessories I am required to get for the installation and I don't know why they are called accessories if I am required to have them but there you go.
Does anyone have first hand experience on what you have to buy in addition to the generator to complete the isntall
jauguston
Bellingham, WA
Posted: 08/15/08 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
The installation template will make life a lot easier. It will show where and how big the holes need to be for mounting and the holes for cooling air discharge and exhaust exit. Ask your supplier about exhaust options.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
nayther
Burbank, CA
Posted: 08/19/08 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Slap it in and take it and the muffler to a muffler shop.
DIRT BIKES RULE
'05 Duramax CC short bed
'06 3005 Rage'n Falcon
94fxds
Rancho Cucamonga ,Ca
Posted: 08/19/08 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
The Onan generator is ok but Honda makes a generator like the Onan that is water cooled,and is made to be permanently mounted and the dimensions are very close to the same size Onan, if I was in your situation I would look at the Honda.I think you can print the instalation directions off the Honda web site
