1fastdad
mo.
dougrainer wrote: Post a Pic of the roof top horn. I believe you have Electric Horns NOT Air Horns. National used both and the Air was an option. When they installed the roof Electric, they did NOT use a dash switch, but did when they installed the optional Air horns. Doug Mine are electric and I thought they didnt work untill I stood outside and had someone blow the horn.
franknsandy
USN-Retired, Skippers, Virginia
I am sure that they are elect, not that you mention it. As they have wire going to them not a hose. Will get a pict up in a few hours.
If they are elect, why don't they work? Is there a relay somewhere that is not working? I do NOT have any bad fuses.
Frank
Frank n Sandy
USN-Retired
96 Dolphin Diesel / 2002 Saturn
Fulltiming since 2004
franknsandy
fast dad
I had the same idea.
I stood out side yesterday while they were sounded and they definately did not work. I
alandodson
Garland, TX
We just returned from our summer vacation and put our motorhome in for oil and filter changes, etc. The air horn sounded like a sick goat on the trip, so I had the shop check for repairs. The horn is required in Texas for the annual safety inspection. The shop found the the horns were full of mud dobbers nests. They cleaned them out and it sounds great.
Alan & Bobbie Dodson
1991 Foretravel Grandvilla 280
Jeep TJ built for 4wheeling
dougrainer
Carrolton
franknsandy wrote: I am sure that they are elect, not that you mention it. As they have wire going to them not a hose. Will get a pict up in a few hours.
Frank
Usually they rust out internally. You have to replace them. Doug
franknsandy
Thanks Doug,
I think I will carry my VOM up on the roof and take a reading while I have DW try to sound them.
Frank
wny_pat
Western NYS
Spray some WD40 into it. Don't over do it, cause it will make a mess.
franknsandy
wny pat
Thanks for the tip
