RV.Net Open Roads Forum: Class A Motorhomes: Where to buy pressure pro-scary blowout!!
 > Where to buy pressure pro-scary blowout!!
ChaosAgent
Wherever we are right now!
Posted: 08/15/08 10:30pm Link  |  Print  |  Notify Moderator
Well, after helping a friend install a Pressure Pro system on his coach and toad, and doing some reading and comparisons, I purchased a Doran 360RV system and installed it today.
The Doran was much easier to setup and install and is working great.
I think my friend is having regrets after seeing the Doran
* This post was edited 08/17/08 04:41am by an administrator/moderator *
'99 American Eagle 40NS
'04 Dodge Dakota 4x4 Crew Cab Toad
DH
DW
Mister & Emma - Designated Coach Cats
Crespro
Camarillo, CA
Posted: 08/15/08 11:18pm Link  |  Print  |  Notify Moderator
I have the Pressure Pro and it works fine. But I tend to agree with ChaosAgent that the specs on the Doran seem better.
With either system, you should consider changing to metal valve stems on your toad. I was able to upgrade my Saturn Vue to the metal valve stems from a Saturn Outlook. The rubber valve stems may fail due to the added weight of the sensor.
Crespro 2005 Diplomat 40 PAQ/2008 Saturn Vue XR AWD
ChaosAgent
Posted: 08/15/08 11:35pm Link  |  Print  |  Notify Moderator
That's one additional point for the Doran. Although my coach tires have metal stems, the Doran kit comes with small plastic collars secured by set screws, that fit over the valve stems before you install the sensors that support the weight of the sensors and keep the stems from flexing due to the additional weight.
ipdretired
Orlando Florida
Posted: 08/16/08 06:36am Link  |  Print  |  Notify Moderator
My 2 cents worth
PP has saved me leaving camp site with low presure twice. So you figure 2 tires that at least may had shredded at $700 it has paid for itself.
Safty is no accident....
Donald & Sally Oberlies sr
Orlando Fl.
2007 Sportcoach Pathfinder/cummins
Yamaha classic
our dog scruffy
Clay L
Sioux Falls, South Dakota
Posted: 08/16/08 12:45pm Link  |  Print  |  Notify Moderator
The Doran system is very new and while it may very well turn to be a good system it has very little history at this point.
The name Doran has been around for a while, but until this year they were a distributor for Pressure Pro with a private labeled PreassurePro system.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
Phillerup
Fishing, USA <*(((><
Posted: 08/16/08 01:31pm Link  |  Print  |  Notify Moderator
Pressure Pro is what we have and it has been great - so has their support from the factory. We have had it over a year. I have read and been told by tire people that the major cause of blowouts is running a tire at low pressure and it heating up and coming apart....This could help prevent that from happening so with me it is a family personal safety thing. It is also nice to be able to get up and punch a couple of buttons and check your pressures without crawling around -- but the safety is the major benefit. I have heard of people with a toad flat tire and actually dragging the toad down the highway on a rim and not knowing the tire was flat back there...
We bought the PP system because it has been around for a few years, there are a lot of them out there in use and is a proven product.
2003 Newmar DSDP 4005 dual slide king bed Spartan 350 Cummins 2004 Jeep Liberty 4X4 tow, SeaEagle boat in basement
