RV.Net Open Roads Forum: Class C Motorhomes: nervous pullling toad
 > nervous pullling toad
Not a Clue
Southern Ca
Posted: 08/15/08 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
I started towing 4 down less than a year ago. I was pretty anxious about at first also. I got lots of help from the people on RV.net. We towed it from Ca to Yellowstone and across Idaho this spring and all went well. I sure like having it around when you want to do something while at the campsite. I also have a camera so I can watch it all the time. Do what everyone told me to do. Take it slow and easy and don't drive faster than you are comfortable. It gets easlier as the miles go by. We take the toad everywhere we go now, whether it is just local or for longer hauls. You will be fine.
Linda B.
2009 29' Fleetwood, Fiesta V10 - The Big Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
Traveling with Robin(friend),Liz(cockapoo)&Buddee(cavalier)
punomatic
Oregon
Posted: 08/15/08 11:03pm Link  |  Quote  |  Print  |  Notify Moderator
I recently made my first trip with a toad. I was very nervous, but after the first 100 miles or so, I almost forgot it was there. It changed our mileage by less than 1/2 mile per gallon, and the convenience of having transportation at our destination was worth the difference. If you are already rigged for towing, I say go for it.
P.S. I had to make an emergency stop during this trip, and I expected to see the toad sailing past us as I slammed on the brakes. The supplemental braking system worked perfectly, and I relaxed after that!
"Then choose for yourselves this day whom you will serve...But as for me and my household, we will serve the LORD."
DW and me, and Pogo (the neurotic terrier) makes 3!
1988 Hawkins Motor Coach 301Q
ronfisherman
SE Michigan
Posted: 08/16/08 05:12am Link  |  Quote  |  Print  |  Notify Moderator
Tow the Toad. We have only traveled a couple of times without the toad. Ended up wishing we had towed it along. If you are worried. Stop and check it every few miles until you feel comfortable about it being back there.
Saf-TTE tire monitor
JohnandCara2
Evergreen CO.
Posted: 08/16/08 09:37am Link  |  Quote  |  Print  |  Notify Moderator
We would tow the toad , have for 10 yrs now. Best advise is watch shadow of toad before changing lanes. Followed that rule and Never backup then you will fine. Best of travels and take pictures.
behengold
Baltimore,md
Posted: 08/17/08 11:42am Link  |  Quote  |  Print  |  Notify Moderator
We just came back from a 5500 mi trip.I wish I brought the toad.Rentals were expensive and when we were in the Black Hills unavailable.I will bring it from now on.
Goldencrazy
madison wi
Posted: 08/17/08 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
I take my Prius along on a tow dolly. I sure enjoy having it and it is nice to have my own car and not have to hassle with rentals. Enterprise was great the several times I used them before towing. Came to the campground in the mountains of Santa Fe and picked me up and returned me when we dropped off the car. It is a bit of a hassle hooking up the tow dolly but I am getting good at it so it gets easier and easier. Anybody out there who has found an easy way to hook up car safety chains without going under the car?
classCcuisine
All Over
Posted: 08/17/08 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
toad. if you take your house everywhere you go, you might as well bring a car along. you might use a tny bit more gas towing, but you more then make it up when you use the toad to get around once your park the ole bed in a shed.
1992 Four Winds Class C 27'
2002 Jeep Wrangler Sahara
A couple of kayaks, bikes, and whatever else we can pile on
MikeMike
St.Petersburg,Florida
Posted: 08/18/08 01:17am Link  |  Quote  |  Print  |  Notify Moderator
Do some online research about weights and state laws concerning break-away switch and onboard brake systems. You will find that a well planned rig will have no problems and you will have very little worries.I really like a rear mounted video system,since alot of the time I have a canoe on the roof of the toad and it's nice to check now and then.
corncob
CT
Posted: 08/18/08 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Towed my Volvo on a dolly behind the Winnebago 31ft for over 5000 miles this spring. No issues and towed very nice. We were in the same area you indicate. No issues at the camp sites as well.
Happy Trails
bsinmich
Holland, MI
Posted: 08/18/08 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
If your car can be towed 4 down I would use the money saved on rentals to set it up for 4 down. I had a dolly for 10 years and now have towed 4 down for 7 years. When my daughter was along and I had the dolly it took us about 15 minutes to hitch up. When my daughter went out on her own and it was DW and myself it took a lot longer and then we wouldn't speak for the first half of the day. Since we got the 4 down setup I do it myself in 5 minutes and she has now started helping also. It is so simple to just put on the tow bars, plug in 2 wires, check and go. I took one trip without a toad and there was no difference in mileage. Enjoy yourself.
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
