Countrybiker
Amite, Louisiana
Can someone out there help me? We are on vacation and stopped at a picnic area today. I started up my generator to run our AC. It started up fine and ran for about 5 minutes then the engine started surging. My rig has only 6000 miles on it and the generator has 80 hours. I checked the gas filter and it was clean. If i let it sit for a few minutes, then start it up, it will run fine for about 45 secounds then start surging again. Any ideas?
Rick & Dee
2006 National Seabreeze
2004 FLHTC as our Toad
bill h
el segundo
Brand, size and model of generator?
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
Texlawdawg718
Longview, Texas
Mine did exactly the same thing the other day and I had my fuel switched off. It might be something simple.
Countrybiker
Amite, Louisiana
Generator is a gas ONAN 5500.
Countrybiker
Amite, Louisiana
I keep thinking it's a fuel problem also but I don't have a cut off valve and I removed the filter and blew thru it so it's not plugged up. I have over 1/2 tank of gas so it's not too low to run.
cableguy574
North Fort Myers, Fl.
All so generators will run not if you have less then 1/3 to 1/4 fuel in the tank
2006 National Sea Breeze 3860 XL
2004 Honda Element Toad/Brake Buddy
JUST Me & My wife & 3 dogs our pictures
FMCA 387898
A member of NUTS
BUTCHPHI
Sacramento, CA
Phil tank and try again. If no luck make sure hose has no cracks.
Anml_341
Ontario, Canada
I would check the state of your batteries. It seems to me that funny things happen when the batteries are not fully charged or have a problem such as a dead cell. Just a thought.
Frank Spence
Ontario Canada
Member: Explorer-RV Club (Canada)
Member: FMCA #F275853
We invite you to check out our websites:
http://flspence.blogspot.com/
http://rvworkshops.blogspot.com/
http://fourseasonsrving.blogspot.com/
50pascals
rochester, ny
If the governor needs adjusting, a small engine will do that alot.
jeffnkelly
St. Louis MO
If you are under a warranty, I'd find a dealer and have it diagnosed / fixed. I would hope that it would be covered. It sounds like either a air - Fuel mixture issue or a govenor issue. A govenor with a bad spring will cause a small engine to surge or rev. You may wabt to check the oil level too. The 5500 has a low oil shut off. It may be just on the low side causing the engine to do goofy things...
Good luck and keep us posted
Smooth Roads!!!
2006 Damon Challenger 372F Triton V10
2007 Ford Edge
JeffnKelly
St. Louis MO
