RV.Net Open Roads Forum: Tar removal (sheesh, it had to be me)
Open Roads Forum  >  Travel Trailers  >  Vintage TT's
 > Tar removal (sheesh, it had to be me)
davidj54
South Alabama
Posted: 08/16/08 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Mayonaise, Yes boys and girls plain ole mayonaise. It'll take tar off and won't damage the finish. Then just wash it off. No bad smells no harmfull chemicals.
My favorite chemical for removing tar wouuld be goo-gone.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
tvman44
Southwest Louisiana
Posted: 08/16/08 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
WD40
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
skipnchar
Topeka Kansas USA
Posted: 08/16/08 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
There are probably 50 different commercial products to remove tar and I've never found one yet that didn't work. Pick one you like and go to work.
mommag
Thornton, Colorado
Posted: 08/16/08 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Cooking oil, baby oil etc. No odor and easy on the hands. The oil haelp loosen and break down the tar. If you look at most lables for contents in Chemical removers I bet you will see "oil" of some type listed.
Pour some on a rag and rub over tar. Some times I use a non scratching spong from the kitchen. Put some oil in a plastic bowl. Dip sponge in and get to work. No mater what you use you will have your work cut out for you. And if you happen to get tar on your cloths. Work the cooking oil into the spot. Let it soak for a while and launder. Got this tip form my grandmother and I saw it first hand when my Grandfather and uncle were redoing the garage roof with the rooled roofing material and, yep, you got it, hot tar. The cooking oil worked great on cloths, tools, even some that happened to splatter on the car, windows, etc.
2005 F250
2007 Pilgrim FW
1 (all I need) Wonderful (most of the time) DH
Life is to short to sweat the small stuff.
jesterdog
Posted: 08/16/08 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
I used almost 3 large cans of WD-40 when my wife drove the X through a strip of road with fresh "oil" which as we all know is TAR!!!!!
After using the WD-40, I waxed the truck. I was very pleased as to how well it worked. You can spray it and watch the tar start to run down the side. I used several red shop rags.
It looks good now!!!
2001 Excursion 3.73 geared V-10
2006 Coachmen Spirit of America 24TBQ
dangerbird
Delanson, New York
Posted: 08/16/08 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
A few years back I had to take my new white service van to a customers site via fresh tar with the small stones. The sides were covered! I used an old bath towel with kerosene and made quick work of it.
Carl
DennyLane
Port Orchard, WA
Posted: 08/17/08 12:20am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all for your suggestions! I think the consensus is WD-40. I have the Costco sized cans, so I guess that'll be it. I suppose I can always try several things If this doesn't work. :-)
...................Denny, (70')....................
1964 Yellowstone Travel Trailer 16'
DH ('69), (Yes, Denny is a nickname & I'm a girl)
Sprogboy #1 (05-'02) & Sprogboy #2 (07-'06)
used to have tiny little camplite,1998
unclejtl
ventura, ca
Posted: 08/17/08 11:35am Link  |  Quote  |  Print  |  Notify Moderator
yep, diesel fuel. I use it in my parts cleaner also. cheaper than parts cleaner and readly available.
1971 Ford F100
1964 traveleze 18
DennyLane
Port Orchard, WA
Posted: 08/17/08 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Dshultz50 wrote:
I used LA Awesome from the Dollar store to remove tar off our rig. Works well and is CHEAP! Be sure to rinse the rig off afterwards.
OK, I found this today & bought 10! I can always return the extra 9 if it doesn't work.
alcaudle
Asheville, NC USA
Posted: 08/17/08 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
How much tar do you have to remove? As others have stated, most petroleum based products will remove it. For small areas, WD-40, bigger areas, get a gallon of Kerosene.
Alan, Donna & Savannah
