RV.Net Open Roads Forum: General RVing Issues: Interior night lights
 > Interior night lights
Bigdog
silverdale wa.
Posted: 08/18/08 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
I forgot the blue lights on my CPAP and they are the brightest in the TT.
GO COUGARS
2001 Ford 7.3L PSD Excursion
Ride Rite air bags
AFE Stage1 air-inlet
4"MBRP exhaust
Hellwig rear sway bar
2005 Keystone COUGAR 304BHS
Tekonsha Prodigy
1200 Equalizer hitch
2008 Thomas w/Mercedes-Benz 78 pass. school bus
adondo
Pasco, Washington
Posted: 08/18/08 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Here's what I did a long time ago. I added small clearance lights inside of the fluorescent fixtures in the bathroom and toilet room. The bathroom light shines out into a central area, the toilet room light is enough to use in the middle of the night. I leave both on all night long, as the small bulbs take very little power. (Note that an LED version of a clearance light would take even less power to run)
Inside the light fixture is an amber clearance light. There is a sub-mini toggle switch for turning on the clearance light. I used pop-rivets to mount the clearance light. It did require disassembly of the light fixture by drilling rivets and replacing with new pop-rivets. Power for the new light is tapped from the existing light switch, which is on the fixture itself. (The same idea would work for other types of lights, depending on the size of the clearance light)
Here's a shot with both lights turned on:
The bathroom with the normal light:
And one with the night light only:
FMCA# F355513. 1997 Safari Continental, 40 foot, 1 slide. Cat 3126B, Allison MD3060. 2000 Durango SLT 4x4 toad with a Blue Ox Aventa II and stopped with a Brake Buddy.
Seen on the Road Photo album
Aiming a Direct TV dish
Matho
New Mexico Texas
Posted: 08/18/08 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
mtnbiktn wrote:
Matho, how long does that light stay on once motion activated? Looks like a good closet light as well if it goes off in a few minutes.
It will stay on as long as there is motion. The light will go out 5 seconds after no motion is detected. Blue light is dark enough to keep my night vision. There is a light detection feature that allows for it to be on in the day and not activate. It can be set for use and forget it until departure.
Chevy 2500 D/A Outfitter 9.5
The Beave
Georgetown TX USA
Posted: 08/18/08 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Try these: http://www.rvsurestep.com/CustomDocs/NightOwl.asp
The Night Owl is battery powered LED with a motion detector. A little pricey, two are <$50 and four are < $100. I plan to get a couple and put one outside over the entry door.
The Beave
30' 1997 Beaver Monterey
(The shortest DP we could find)
2005 Honda CR-V
Remco surge brake
