dieselmec
Mississippi
ihave a onan 4000 emerland plus and when you try to crank it it dies as soon as you let up on on the start switch need help
thanks william
Live Simply,Love Generously,Care Deeply,Speak Kindly, Leave The Rest To God!(In Our Heart's Forever Our Companion Maggie.)
jauguston
Bellingham, WA
The generator electronic controller must see AC voltage being produced. If it doesn't see AC voltage it will shut off when the starter is released. My Honda EV4010 was the same way. My voltage regulator failed and it acted just like you describe.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Teebone56
Dublin California
I am having the same problem, my generator is new..kind of pulses first then dies???
2009 Weekend Warrior SL 3005 Superlite Billet Edition
2007 Silverado 2500HD CC SB 4X4 6.6 D/A
04 DS 650 Baja X
07 Rhino SE
Fevermeister
La Vergne TN
Probably a bad voltage regulator. You can find aftermarket voltage regulators for Onan all over the internet. Check the resistance between the brushes, should be the same resistance you read between the slip rings. Should be somewhere around 28 ohms. The replacement voltage regulator that I bought for my Onan said the warranty would not be valid if the reading across the pins coming from the brushes exceeded 28 ohms.
jeffnkelly
St. Louis MO
You may want to check your oil levels. There is a low oil sensor that will either cause the engine to start and die shortly after. OR I have heard that some will pulse as the oil level flipflops with the crank...
Just a piece of free advice..
Good luck and keep us posted
Smooth Roads!!!
2006 Damon Challenger 372F Triton V10
2007 Ford Edge
JeffnKelly
St. Louis MO
e&emc
Davidson, NC 28036
It is the voltage regulator. Talked to Onan pro and he was right. This fixed mine and that has been about 2 years ago. Get the number off the old regulator to get an exact replacement. I found mine on the internet about i/2 of Onan's price and have had no problem with it.
Hope this helps, Ed
chucl66
Milton, Florida
Just had the same problem. I was the voltage reg., replaced works fine! Reg. cost 400.+, simple replace, has plug in on end of line!
Chuck
Chuck & Laraine
tropical36
Southwest Florida_USA
Why does a voltage regulator have to cost that kind of money? That's about as ridiculous as the Memorex DVD player we bought at Kmart yesterday for $27.50 + tax, which was still under $30 bucks and it costs me at least $20 to ship a mid sized package somewhere.
Oh well, maybe it's a rare American made product.
Sure glad Guardian sent me that whole box of parts for my 10 year old 5.5 Generac... free of charge, but that deal is over. The two great guys are gone and the whole facility at that location is scheduled for shutdown, which may have accounted for the freebees.
I posted that rare event, as I always do, when awarding ....attaboys...so I hope some of you took advantage and got your free spare parts while the getting was good!
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal, with a tag axle and one slide, on a 1997 P32 Chevy chassis....7.4 Vortec Engine
Teebone56
Dublin California
Thanks guys I am still under warrenty, so that helps.
Herewego
Larry Cad drives the ACORN Express!
Can you pull a code off of your generator to see what it is saying the issue is??????
2004 Coachmen Aurora on a FORD V-10 Chassis
2004 Jeep Liberty
Don't take your organs to Heaven. Heaven knows we need them here! Dave has a dog named Muffy and Mike owns a Cockapoo!
