RV.Net Open Roads Forum: What is the Correct GVWR for the K-Z Sportster 2910????
Search only in Toy Haulers
 > What is the Correct GVWR for the K-Z Sportster 2910????
ugeesta
Northeast Ohio
Posted: 08/17/08 05:14am Link  |  Quote  |  Print  |  Notify Moderator
Ok. I have become officially confused on the weights of the K-Z Sportsman Sportster 2910.
Looking at three different areas, I find three different weights. The one that befuddles me the most, is the weight listed on the inside of the cabinate door of a trailer at a local dealers lot.
------------------ 09 -------- 08 ----- Dealer
------------------ Web--- Brochure - Trailer
UVW----------- 9670,--- 9285,--- 9635
DHW----------- 1705,--- 1555
DAW----------- 7965,--- 6000,--- 6000
NCC------------ 4030,--- 4115,--- 1392
GVWR-------- 13700,- 13400,-- 12000
Ext Height--- 11'-6",-- 12'-4"
Ext Length--- 31'-11",- 33'-9"
The trailer was manufactured on February 2008 which was before the publication of the 2008 brochure specs. It has 16" rims on eight lug axles, so I find it hard to believe that 12,000 lbs GVWR is correct.
My guess is that the 09 web specs are correct, but then I question why it took so long for K-Z to figure out the specs on the trailer when they are the ones that manufactured it .
Did they re-design the trailer between 08 and 09?
We are thinking on buying the trailer at the dealers lot, but then I don't want to buy a problem if it can only carry our quads.
Thanks.
2002 GMC Seirra 2500HD 8.1
2007 Honda Rancher 420
2002 Honda Rancher
1 wife & 3 cats
2003 25' KZ Sportsman Sportster...Yamaha EF2800i
Forget San Francisco, I Left My Heart In Colorado
Dieselgem
Pennsylvania
Posted: 08/17/08 05:30am Link  |  Quote  |  Print  |  Notify Moderator
Why not look under the trailer and see if it has 6 or 7,000 lbs axles? You could also call KZ and give them the serial number and they will give you the information.
08-KZ Escalade 41'CKS Escalade Pics
2008 F450 Super DutyTruck Pics
97 & 2003 FLSTS
2003 FLSTC (Wife's)
shadoow
South Texas
Posted: 08/17/08 05:51am Link  |  Quote  |  Print  |  Notify Moderator
i ran into this same problem when we were shopping trailers & as it turned out, the actual weight of the trailer when i went to the scales was different than any of the published weights.
I'm towing a KZ 33P toy hauler with a 2008 GMC D/A. I carry a full dress harley that weighs around 900#. All my weights are within limits although i'm pretty much at my GVWR rating of 9200#. When i weighed the trailer i had it loaded for camping with the harley. In the truck, i had me & the wife, a full tank of fuel & the mutt. I don't remember all the #'s but like i said, i was at the GVWR of 9200#, I was under the GRAWR by around 1000# (and even more on the front axle) and my combined weight was under 20000# which is more than 2000# under my rating for this.
I tried doing my homework with the #'s as much as i could before getting the trailer & even weighed my truck by itself to see how much pin weight i could take (came out to be around 2200#), but unless you can find someone that has weighed the trailer you're looking at, it's very hard to tell what the actual weights will be.
Also, the brochure weights are without any options so i wouldn't go by them. The weight that should be the closest is the one posted inside the trailer on a kitchen cabinet door, but even that was wrong in my case
The KZ 2910's are nice trailers. Good luck...
KZ 33P Toyhauler
2008 GMC 2500HD D/A
2006 Ultraclassic
1978 FLH
JIMNLIN
Big Cabin, OK
Posted: 08/17/08 05:56am Link  |  Quote  |  Print  |  Notify Moderator
it probably is the '08 year made specs as NHTSA has just issued a rules change for RV manufactor regarding GVWR/axle weights and UVW numbers dated 6/2/'08. See new RV regs web. Scroll down about halfway to S10 paragraph for the new RV rules changes.
I would think KZ would use the old rules regarding their axles. Also some manufactors were already compliant anyway. As dieselgem says the tags on the axles may have your answer.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
ugeesta
Northeast Ohio
Posted: 08/17/08 05:59am Link  |  Quote  |  Print  |  Notify Moderator
What should I look at that will tell me if it is a 6000 or 7000lb axle?
kaydeejay
SE Michigan, USA
Posted: 08/17/08 06:12am Link  |  Quote  |  Print  |  Notify Moderator
If it's GVWR you are looking for that, along with the axle ratings, is on the external VIN/Certification/Tire pressure label on the outside of the trailer.
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
Dieselgem
Pennsylvania
Posted: 08/17/08 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Yes, there should be a tag on the axle. Also, KZ weighs the units for over a year now when they leave the factory. When, I scaled mine after picking it up the numbers were almost idential. You may have a typo error. Why not give the factory a call. They make a nice unit and are good company.
