RV.Net Open Roads Forum: Tech Issues: Need sm. 12v generator
 > Need sm. 12v generator
DougnDee
Corvallis, OR USA
Posted: 08/18/08 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
pnichols wrote:
Are you only interested in a new generator?
If not, you might look for a Honda EX650 on the used market. The are very reliable and very quiet - 54 dB at full power (the new Hondas are about 53dB at idle). This little genny will drive about a 45 amp charger or converter for your RV's 12V electrical needs and topping up of your rig's battery bank.
Mine comes from the 1980's and starts right up even after months of sitting around. Metal case instead of plastic -> plastic is used for the newer Honda's. Runs 7-8 hours on 1/2 gallon of gas. Around $250 on the used market. Built like a tank but small and it weighs about 48 lbs. Honda discontinuid them around 1999.
Good idea! Thanks.
Doug,Dee & Shoni
'02 Cameo LXI,
'07 Dodge Cummins 2500,6Spd,Quad,4X2,LWB,PacBrake,AirLift, Bright White
Takereasy
South Texas near Victoria
Posted: 08/18/08 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
60 or 80 amp alternator being turned by a small Honda or Briggs engine. Modify the alternator to put out 110 volts than add a nice charger to it, or use the alternator direct which I have done for many years. Sips very little fuel and is dirt cheap if you can scrounge parts up.
Visit our site
Jodi & Richard
98 Tiffin Allegro Bay 34' w/Slide
01 Ford Ranger 5 speed - US Gear Brake
00 HD E-Glide
My Last RV Rebuild
teb1272
Memphis
Posted: 08/18/08 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
There is a post on here somewhere about the generators like the one you mention at "Joes"-you might want to look at it before you decide. Many of these copies of the Honda and Yamaha types end up being a good deal, but sometimes you have problems. They seem to be nearly as quiet, but probably don't last as long.
