RV.Net Open Roads Forum: Class C Motorhomes: Adding an extra fresh water tank?
 > Adding an extra fresh water tank?
4rvsearcher
Corona, CA
Posted: 08/17/08 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
We are debating between a toyhauler with a 100+ gal water tank and a C class with just a 40 gal tank. We really like the C class, but we like to dry camp and 40 gal is pushing it for a family of 4. How hard is it to add an additional water tank to a C class? We are looking at the Jayco Greyhawk 31SS.
Thanks
kaydeejay
SE Michigan, USA
Posted: 08/17/08 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
First of all, can the "C" carry another 480#? (that's 60 gallons at 8#/gallon).
Second, is there a place to put a tank? (inside, under the chassis, on the roof)
Then you will need to plumb in another water pump and controls.
Can it be done? - sure but it might be a lot more work than you first thought.
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
Goldbrick
Royal Oak, Michigan
Posted: 08/17/08 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
Rather than remodel a thought out design why don't you carry a rubber bladder that you can refill your present system with. Water sources are usually not too far from most dry camps.
tom_kat
way upstate new york/lake george area
Posted: 08/17/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
it all depends on the way its made on our rv class A it would be easy to add one under the bed on our older Class C there no room to put one.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
dmatt
Ventura County, CA
Posted: 08/18/08 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
I would think the biggest issue would be the added weight. Depending on the size, model, etc., you will be very close to your max. before adding a tank. With the added tank full of water, you may not have any capacity left to carry other things in the MH.
2007 Four Winds Dutchmen 29R-Ford E-450 V-10 towing a 2008 Toyota Matrix XR
2007 Toyota 4Runner(V-8) towing a 2006 Reinell 220LSE, 5.0L, 280hp GXI
Our camping photos
under the stars
Elsinore 4 stroker
Lake Elsinore
Posted: 08/18/08 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
We carry 2x6 gallon tanks. 50 gallons of water for a couple of days is not bad. If you add another 60 gallons of water you need to keep in mind that you need that much more room in the black and gray tanks.
younchem
Lafayette, LA
Posted: 08/19/08 11:35am Link  |  Quote  |  Print  |  Notify Moderator
We only have 30 gals FW in our C. It is a problem.
We carry extra containers that we can fill before reaching the boondocking spot and almost double our FW capacity. Doing it this way we don't have to drive far with the added weight. But containers get in the way. They have to be dumped into the FW tank when needed adding work.
The 30 gal. grey water tank gets full quickly, however, and this is usually time to move and dump, flush and fill. By then we find that we've used about 40-45 gallons of FW as not all goes in the GW tank. I would recommend to any manufacturer that they could install a larger FW tank than the GW tank for these reasons.
I thought about adding another FW tank as we also have the room but didn't give it serious thought.
NTORACN
Moreno Valley
Posted: 08/19/08 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
I carry 10 gals of fresh water on the motorcycle trailer. If my grey tank gets full, I put the cap on the dump line and open the grey tank first, then the black tank second. I close the black tank before its full and then the grey valve second. This allows me to use the mostly unused black tank capacity to store my extra grey water.
This allows me to dry camp (Ocotillo Wells, Lucern Valley, Slash X) for up to 4 or 5 days on 35 gals of MH water plus my extra 10 gals. Thats a family of 4 taking showers every day, brushing teeth, cooking......... washing dishes is the biggest water waster once I got the family to cut the showers down. Its amazing on how little water you can live on daily when you have to.
tntretro
pa
Posted: 08/20/08 10:25am Link  |  Quote  |  Print  |  Notify Moderator
I added a 40 gallon tank between the frame rails in the back with a pump that I can use for powerwashing or filling my coach's fresh water tank. No problem.
younchem
Lafayette, LA
Posted: 08/20/08 11:15am Link  |  Quote  |  Print  |  Notify Moderator
What type of RV?
