RV.Net Open Roads Forum: Tow Dolly help. What kind should I buy?
Search only in Dinghy Towing
 > Tow Dolly help. What kind should I buy?
Herculez
North Carolina
Posted: 08/17/08 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
I assume there must be several types of tow dollys, but I do not know what type or which would be the Best, Safest, and can be handled by one person.
Can you all help me with infomation?
Thanks,
Britt
mowermech
Billings, MT
Posted: 08/17/08 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
I would go for one that has brakes installed. Surge brakes are OK, electric brakes are better, some say.
If it folds up for storage, that would also be a plus.
Since there are various sizes, make sure your vehicle fits the dolly.
I have heard that the dollys which have the steerable wheels are better than the turntable styles. I don't know, I have never used one.
Good luck in your search.
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, Std. cab, LB, 5 speed, 4.10 LS diff., Jacobs Rambrake, 273,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '06 Jeep Liberty CRD
Towed: '06 Jeep Rubicon Unlimited
Chief enforcer
Interlaken N.J. U.S.A.
Posted: 08/17/08 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
I use a MasterTow with elec. brakes and it works fine!
dbates
Marion, Indiana
Posted: 08/17/08 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I've pulled a Demco KarKaddy SS for 3.5 years, 28,000 miles & am well pleased with it. It has surge brakes which have worked quite will even in the mountains & we have been in quite a few (see map below). The tongue folds back & the ramps fold up to reduce storage by almost 50%. It is heavily galvanized so it should never have a rust problem. It is built to haul large toads and the tongue weight will not exceeding 100#. Because the wheels pivot rather than the toad wheel plate I’ve been able to make full 360 degree tight turns without the dolly fenders touching the toad. Many places sell for less than the “suggested retail” so shop around.
Click HERE for their website.
Dave
Plus New Brunswick, Prince Edward Island & Nova Scotia
Bobbo
Memphis, TN
Posted: 08/17/08 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Stehl Tow Dolly with electric brakes and like it fine. It has the turntable, not the steerable wheels, but I don't have a problem with that. It does not fold up, but it isn't that big to begin with. I am happy with it. I will keep it for several years until I trade my current toad and buy one I can tow 4 down.
Bobbo, Linda and the furry kid (German Shepherd)
'07 Winnebago Outlook 31C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
steelpony5555
Copperas Cove Texas
Posted: 08/17/08 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
any of the 3 major brands mentioned above are pretty much the same, 2 wheels, set of ramps and a hitch--but yeah get it with the brakes--
05 Trail Bay 27DS
07 Tundra SR5 4.7
00 Harley Electra Glide (My Baby)
07 Civic for cheap gas
Margarita machine---nothing better then sittin in the shade on a hot day sippin a Margie!
Herculez
North Carolina
Posted: 08/18/08 02:56am Link  |  Quote  |  Print  |  Notify Moderator
Question on Brakes.
First I need to tell you that I know I may be breaking the law so please do not scream at me.
If I was to use this dolly on the back of my fifth wheel would I be using a seperate brake controller for the electric or the surge brakes?
In other words would I have 2 brake controllers in my truck or can I just use the one?
Britt
1fastdad
mo.
Posted: 08/18/08 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Herculez wrote:
Question on Brakes.
Britt
If you have surge brakes there is no controler and no you won't be braking the law unless you get over length.
vic46
Red Deer, Alberta, Canada
Posted: 08/18/08 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Herculez wrote:
Question on Brakes.
Britt
Do the rear wheels down on the toad constitute the third trailer??????????? I think I would want to get that real clear before starting the "parade". Both a licensing and an insurance issue!!!!!!!!
Vic
Bobbo
Memphis, TN
Posted: 08/18/08 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Like was pointed out above, surge brakes need no controller. Electric brakes probably WOULD need a separate controller since you have to adjust the controller to the brakes and the two trailers have different brakes. Trying to do 2 controllers would be interesting though. You would probably have to use the center pin as the second brake controller and have the 5er pass that pin through to the correct pin on its 7 pin socket.
The third trailer consists of everything attached to the ball behind the 5er.
