RV.Net Open Roads Forum: Tow Vehicles: Best tire guage to check dually
Search only in Tow Vehicles
 > Best tire guage to check dually
Monty-Rob
Charlotte,NC
Posted: 08/17/08 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
What have you found to be the best/easiest tire gauge to check tires on a dually. Mainly the inside rear tires.
On my F450 the outside valve lines up with the inside valve but it is still a bear to get a good reading.
F450 door says 80psi in front and 75psi in rear....it came from the dealer last week with 90psi in all!
Dennis M M
Geneva, IL
Posted: 08/17/08 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
You want a dual head gauge like this one
You can pick one up at almost any truck stop.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'05 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro;
Optima Batteries
coolbreeze01
Redding, Ca
Posted: 08/17/08 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
What do you mean by "lined up"? The stems shouldn't be close enough together to cause a problem. If you don't have them, I'd get extended stems for the inside tires. Stems should be indexed away from each other, and use a duel head gauge.
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
JRMora
Now Located in Columbus, GA
Posted: 08/17/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
coolbreeze01 wrote:
What do you mean by "lined up"? If you don't have them, I'd get extended stems for the inside tires. Stems should be indexed away from each other...
Actually, my valve stems are indexed together (they line up). This is what it says in the owners manual and how I've had them for 100k miles. I have a good dual head tire pressure gage (standard truck tire gage - goes to 150 psi), and have never had a problem with either the gage or the valve stems. And yes, I have the standard extensions that allow checking with the caps in place.
Juan
2004 Dodge Ram 3500 CTD/4X4/DRW/6 Speed
2005 Cedar Creek 36RLTS
Truck: B&W, Prodigy, Quadzilla, MBRP, Pac Brake PRXB
Trailer: Full Trail Air, Onan Marquis Gold 6500LP, Dual AC, King Bed
My RV Photos
Us: Juan/Lyn/Nick/Quino/Rico (3 Boys!)
GeeksRUs
Sundre Alberta
Posted: 08/18/08 07:56am Link  |  Quote  |  Print  |  Notify Moderator
I've installed braided extenders that curve to the front... also turned the outside wheel so that the valve extenders are somewhat opposite from each other.
GeeksRUs
2008 Big Horn 3400RL
2003 F350, PowerStroke, 4x4, SuperCab, LongBox, SWB
RV Home Base @ Coyote Creek, Sundre Alberta
donn0128
Pronounced Ore-gun
Posted: 08/18/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Go to your local truck stop. They have all sorts of them available specifically designed for use on dual tires.
Donn
sbmowrey
DuBois Pa
Posted: 08/18/08 09:25am Link  |  Quote  |  Print  |  Notify Moderator
The main thing for me was to have one that allows you to stay on the valve stem for inflation and checking so once you have it your good to go.
2002 GMC 3500 DRW 4x4 8.1/al
1993 40ft Spinnaker 2 slides/3axles
hook47
Olympic Peninsula, WA, USA
Posted: 08/18/08 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Do a search for "psiclops tire gauge". I have one that is rated from 35 to 180 psi and has 2 chucks on unequal length hoses that you hook up to 2 tires at a time and can equalize pressures and add pressure to both at the same time. Works great.
2008 Chevy 3500HD LTZ 4X4 CC Duramax/Allison & 2007 Mobile Suites 36TK3
Clattertruck
Centennial Colorado
Posted: 08/18/08 10:59am Link  |  Quote  |  Print  |  Notify Moderator
For my F450 I had a truck tire store change the inside stems to a long ones like the big guys use. Traditionally, the stems should be opposite of each other. The new stems come way out into the outside wheel hole and are very easy to service.
Clattertruck
2008 SD F450 PSD 6.4L CC 4X4 DRW, Lariat Auto trans 4.30 LS, 2008 Snowriver 108 truck camper. Jeep Unlimited Rubicon as toad.
Monty-Rob
Charlotte,NC
Posted: 08/18/08 11:41am Link  |  Quote  |  Print  |  Notify Moderator
I looked at the psiclops web site and like the idea of balancing tire pressure of both wheels at the same time. A little pricey at $99 but looks good.
