drandallx
upstate new york
i bought a 1988 rockwood 350xl . it is a rear engine pusher but the engine is a 460 ford engine with a c6 trans.,because of fuel prices i would like to convert thans. to a EOAD and gain overdrive. i looking for someone who has done it or a tech. who has info . i've only got a 14" driveshaft now so i need a short tailshaft and a harness to power the trans. with a carb. engine .thanks for any help denny
don/lou
Brandon MB Canada
It will cost you more to convert than you will ever save on gas!!!
Don & Louise FMCA F190607
00 Coachman Catalina 330 MSB /F53
F&R air bags and Koni Shocks
05 Buick Century- Remco Lube Pump & Blue OX
milazzo
bakersfield ca 93307
Put a 2 speed Gear Vendor unit behind your c6.. Stronger,2 more gears and split shift..
Milazzo
KOG
Winterville GA
Given that you have a 14" driveshaft now I think you can forget any changes. Both the GV and the EOAD will be too long to work. Drive it as is or trade it.
SteveRankin
Sequim, WA
The splitter would be far cheaper and easier to install, plus it would give more ratios, but it probably wouldn't work in a pusher with a short drive shaft.
IMHO, the cost of converting to the newer transmission would take forever to pay off and I doubt it would make much of a difference in fuel economy because the OD ratio may be too tall to be used very much.
Another alternative would be to replace the rear axle with a 2-speed axle. IMO, a more elegant solution but it could be pricey too.
Steve & C. J.
"Gracie" the Rough Collie & "Bo'sun" the Bichon Frise
2009 Arctic Fox 29V
2005 Chevy 2500HD Duramax 4X4 Crewcab
Hensley Hitch
TruControl Brake Controller
Our Beaver Technical page
Wildlife rescue at the Northwest Raptor Center
RLS7201
Gladstone, MO
Hi Denny, According to this Web Site, an E4OD is 4" longer than a C6. That would leave you with a really short drive shaft. If you insist on pursuing the change, you'll need an aftermarket electronic controller. Baumann Engineering has a very good controller for the E4OD.
Richard & MichĂȘle Shields
Northland Good Sams
1995 Bounder
32H F53
Banks, TruTrac, Vena
2003 PT Cruiser Pusher
FMCA 395470
Web Page
Retired and traveling on your hard earned SS $$. Thanks for your support.
goldendagger
moving
or do a gear change if you are running light and staying out of hills?
who left the light on? is it me or are we leaning downhill. where did the dog run off to
Gale Hawkins
Murray, KY
Why do you think an OD will improve mileage? I did see this set up in a MH about 10 years ago. The owner had moved to a DP and stated he liked it but due to cooling issues I think he had replaced the radiator but he towed a huge trailer doing trade show events for motorcycles.
KOG
Winterville GA
A two speed axle is also a non starter because it will also require a shorter driveshaft. You're right back to drive it as is or trade. Unless you've got room in the rear of that thing to move the engine back 4" to accommodate the OD transmission. Which would still mess with weight distribution somewhat. But if your coach is the 35' that the model number indicates it would still be much better balanced than one with an inline diesel in the rear so moving the engine might work. Still highly unlikely to be worth the cost or effort.
1fastdad
mo.
The GV spitter is more than 14" long if I remember correctly.
