RV.Net Open Roads Forum: 3.51 amp draw on chassis batteries.....MYSTERY SOLVED
 > 3.51 amp draw on chassis batteries.....MYSTERY SOLVED
HK40USP
Santee,CA
Posted: 08/17/08 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
It was the 12v duvac wire, I have it connected to the + side of the chassis relay solonoid (from the alt.), now I have to figure out why it is pulling amps when connected, at least I know where the problem is ..removed the wire and now the draw is .14amps ...normal, I believe.... thanks for all your wisdom and theories....Jim
Hey all... I have a .83 volt draw ( 3.51.amps) on my chassis batteries...any idea's on what to check?
this draw is on the chassis batteries not coach....thanks
* This post was last edited 08/22/08 08:37pm by HK40USP *   View edit history
1996 Gulfstream Sunvoyager, 34 ft, no/slides
Spartan Chassis, B5.9 230 hp Cummins
Tom_Anderson
Danville, CA
Posted: 08/17/08 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Do you mean .83 amps? How are you measuring it?
bldrbuck
Boulder, Colorado
Posted: 08/17/08 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
All of the various things that have displays. Radio, speedometer, gages, maybe the hood or trunk light there must be more. .83 would be less than an amp. Good luck.
don/lou
Brandon MB Canada
Posted: 08/17/08 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
The fridge has a draw on the control board even when turned off inside
but should be on house bat
Don & Louise FMCA F190607
00 Coachman Catalina 330 MSB /F53
F&R air bags and Koni Shocks
05 Buick Century- Remco Lube Pump & Blue OX
urmine351
fort smith, arkansas
Posted: 08/17/08 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
my tv does even if its off, and my sat. reciever, i have to unplug both to kill the drain.
1996 Safari Serengity, 3126 Cat,Allison 6 speed, 38' DPNS, 2005 Honda Element,vip tow brake. doran tire sensors, Magellan750Nav,
and 1 good looking wife, and missy and Alex(died 11-03-06) and AJ, born 09-06-06 my carins.
FMCA # F374886
HK40USP
Santee,CA
Posted: 08/17/08 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
tom...I have a multi-meter set on 20vdc...measure is across the knife switch on the neg post.....Jim
Tom_Anderson
Danville, CA
Posted: 08/17/08 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Set the meter for 10A instead of volts and measure it again. That will give you a much more meaningful reading. Any significant draw should give you a reading of full battery voltage (12.6V) when you measure voltage drop (how you're doing it now).
Capt. Flipper
Farmington Hills, MI
Posted: 08/17/08 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
If you are getting .83 volts across the open knife switch, you don't have a problem. VOM's are typically 20,000 ohms of internal resistance per volt and that translates into a very small parasitic current draw.
Al & Mary Lou
99 Dolphin
06 Chevy HHR w/Unified Towbrake
DeweyClawson
Enon Valley, PA
Posted: 08/17/08 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
With a .83 volt drop across a closed switch, it sounds like you have a very dirty sw, bad switch contacts. resistance should be very close to ZERO. This would cause a ZERO voltage drop across a zero resistance. JMHO
The fool learns from his own mistakes.
It is the wise man who learns from the mistakes of others.
HK40USP
Santee,CA
Posted: 08/17/08 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
the switch is open (measuring across open switch) and all contacts have been cleaned....jim
