RV.Net Open Roads Forum: Class A Motorhomes: New Barn for the Motorhome
 > New Barn for the Motorhome
Page of 6
Rich D.
New England
Posted: 08/18/08 08:14am Link  |  Quote  |  Print  |  Notify Moderator
When I built my barn/garage, it was too far away from the house septic system so I built a small septic system for the barn. It is large enough to handle any RV use and was not very expensive to do. Most towns allow a homeowner to do their own work as long as the inspector approves it. I also connected the sewer connection to an extra RV "Site" with full hookups. Over the years guests have used and enjoyed the spot. I ran a 3/4" black plastic well pipe with softened well water to the barn and drain it in the winter.
Rich D. Wanderlodge LXi 43'
TippleUnduly
Cranbury, NJ
Posted: 08/18/08 08:28am Link  |  Quote  |  Print  |  Notify Moderator
I built a barn that matches the design of our home. We store our 30' coach + 2 classic cars. The very best feature has been that we do not have any mice in our vehicles! I hate them and their messes. We made sure that all the walls and doors create a tight seal that keeps them out. Our concrete floor sits about an inch and a half higher than the apron and the doors swing tight against that lip.
Bill
Bill K
2001 SeaBreeze 30'
Workhorse 18000 GVW
No Slides, Awnings, Wide body, Toad, or Problems!
Maj Easy
Oklahoma
Posted: 08/18/08 08:47am Link  |  Quote  |  Print  |  Notify Moderator
if money is not a problem, i would at least get a quote on putting in an oil changing pit... have it run the full length of your motorhome... even if you have someone else change your oil it still would be nice to be able to easily get under your coach for inspection purposes.....
sorry i hadn't read the complete thread before placing my reply, an earlier post already has made this suggestion
* This post was last edited 08/18/08 09:17am by Maj Easy *   View edit history
2009 Safari Cheetah 42ft tag axle by Monaco
400hp C-9 Cat 6sp Allison in motion satelite
Quad screen color LCD gps factory installed in dash
Dinghy is a 2600lb 08 Toyota Corola 5-spd manual 37mpg
Tow Bar by Blue Ox Avanta LX 10K
Equal balancing polymer
ShapeShifter
Buffalo, NY
Posted: 08/18/08 09:46am Link  |  Quote  |  Print  |  Notify Moderator
CurtisG wrote:
Takereasy wrote:
Here is what you need for pumping sewage.
Pump and Tank
Good idea--I recently added a MIL bedroom & bath to my home and had no way to connect to existing plumbing (on a concrete slab) so I purchased that system---works beautifully. Would work well for motorhome.
Curt
That makes sense in that kind of situation. But if it's just for the motorhome, for that kind of money you can get a macerator system. It could then be used anywhere, and not the usefulness of the investment would not be limited to just the home dump station.
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
T18skyguy
Eugene, OR
Posted: 08/18/08 10:30am Link  |  Quote  |  Print  |  Notify Moderator
If you do your own maintenance don't skimp on the lighting. I thought I was good to go when I did my hangar shop and ended up redoing it with twice as much lighting. My eyes are not as young as they used to be. Good luck and I hope it turns out great for you.
Retired Anesthetist. Pilot with mechanic/inspection ratings.1996 Jayco C 22 foot with 460/Banks Powerpak/Bilsteins.Wife and daughter. Two cats which control my life. 1975 Ford F-250, 84 Coupe Deville, Thorp T18, tons of tools and tons of junk.
Takereasy
South Texas near Victoria
Posted: 08/18/08 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
ShapeShifter wrote:
CurtisG wrote:
Pump and Tank
Curt
Maybe, depends on your needs. It's not "that" much more and it will pump faster than you can drain your tank using the 3". So, a) You don't wait forever b) The full flow of a 3" opening cleans the solids out of your tank way better than a macerator. I have both.
Visit our site
Jodi & Richard
98 Tiffin Allegro Bay 34' w/Slide
01 Ford Ranger 5 speed - US Gear Brake
00 HD E-Glide
My Last RV Rebuild
OkStateRV'er
Oklahoma
Posted: 08/18/08 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Want to say thanks for everyone's comments/suggestions on the barn.
2008 Dutchstar 4304
2008 Honda CR-V EX-L, M&G brake system, Falcon 2 tow-bar, Garmin nuvi 350 GPS
Old Coot
Mansfield, Ohio
Posted: 08/18/08 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
A lot of times I find myself wishing I would have added a door to the rear of the barn, for flow through ventilation.
92 28ft Bounder
06 Corvette C6
07 Silverado
Janet&Jack Sabrina(Husky)
MRUSA
Boca Raton, FL
Posted: 08/19/08 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Regarding sewer connection, where should it be located? In the barn? Smelly. Outside the entrance door? Then you have to move the coach out to dump it. Or, away from the barn altogether to keep smells at bay?
Marc, Boca Raton FL
2003 Beaver Monterey 40' triple slide
Blue Ox TruCenter
Acura MDX toad
Unified Tow Brake
Pressure Pro Tire Monitor
Garmin 2610 GPS
Datastorm D3/7000
Sirius Radio
Tivo on board
rvten
Crossville,TN
Posted: 08/19/08 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have an indoor dump in our garage. Smell does not last long. Just open front door and turn on exhaust fan in garage. The smell comes from the MH waste tank vents not the dump conn.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008
Class C passed Class A owner
Pontiac G6
There is NO such Thing as a B+
Page of 6
