RV.Net Open Roads Forum: Tech Issues: generator surges
 > generator surges
mickbear
georgia
Posted: 08/18/08 06:32am Link  |  Quote  |  Print  |  Notify Moderator
i have a 2004 MicroQuiet 4000 with about 43 hrs and its began surging, it starts ok but surges. i can spray carb clearner in the carb and the surgung stops for 30 seconds or so .any ideas what might be causing this?
thanks
mick
2005 TIOGA 23E
tvman44
Southwest Louisiana
Posted: 08/18/08 06:52am Link  |  Quote  |  Print  |  Notify Moderator
Dirty carb.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
dougrainer
Carrolton
Posted: 08/18/08 08:57am Link  |  Quote  |  Print  |  Notify Moderator
43 hours in more than 4 years= NOT running the APU enough and the fuel has varnished in the carb and clogged the jets. Onan Service centers only replace the carb, they have no rebuild kits. But, you can rebuild them by taking them apart and cleaning the jet orifices. The gaskets/Orings rarely are destroyed when you take the carb apart. Doug
PaulJ2
Northwest Oregon
Posted: 08/18/08 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
Surging means running too lean. As other have said, dirt or varnish in the carburator jets. Adjust the main mixture screw if it has one. Many now days don't.
TEXAS
Centerville Tx
Posted: 08/18/08 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Try running some carb cleaner in the gas. I have had good luck with that. After you get it running ok. Run it at least once a month. To keep the fuel system clean.
smithlkd
Alabama
Posted: 08/20/08 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Mickbear,
Clean carb with seafoam then change the oil. Sometimes you can have the proper level of oil and the low oil sensor will give false signals at the control board and cause a surge condition even with a new carb and proper tuning. Old oil will foam and carb cleaners will thin oil before you know it. Always change genset oil every 50 hours or every three months during the run season. Winterize with with fresh oil and run for one hour at half load every month.
Lynn Smith
1984 Allegro P30 chassis
gunny357
North Carolina
Posted: 08/21/08 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
smithlkd wrote:
Mickbear,
Where'd you come up with this information?
Camper Ken
Oregon
Posted: 08/22/08 10:14am Link  |  Quote  |  Print  |  Notify Moderator
I also have the Onan 400 generator. On our last trip the generator would surge a little but only when running the AC. We were at about 5,000 feet altitude and I did set the altitude adjustment on the generator. Never had the surging problem before. It's about a year old with 30 hours. I run it at least once a month for an hour or two under 1/2 load to exercise it.
Any thoughts on this? Thanks...
2007 Winnebago Access 31c
(2006 Ford E450 chassis)
mickbear
georgia
Posted: 08/27/08 06:45am Link  |  Quote  |  Print  |  Notify Moderator
two things i found out and maybe will help someone in the future.1St run the gen every month ,2ND check the altitude adjustment on the generator,some how the adjustment knob had gotten moved all the way over to the highest setting,i live in ga so i moved it back to the lowest setting, i filled the main tank and added carb cleaner and kept cranking the gen and running it and spraying carb cleaner in the carb area after a while the surgging stoped.thanks for all the help
 > generator surges
