RV.Net Open Roads Forum: Best way to park MH during hurricane?
 > Best way to park MH during hurricane?
Page of 8
TMitchell
Punta Gorda, Fl.
Posted: 08/18/08 06:34am Link  |  Quote  |  Print  |  Notify Moderator
I was wondering what the consensus is as to the best way to park a MH, when strong winds are expected. We are probably going to have somewhere around 90 MPH winds tomorrow. I have the air tanks purged and the jacks deployed, just enough to take a little weight off the tires and level the MH. Don't know if it would help the MH ride out the wind with the jacks up or down. On my system I can't deploy the jacks without the air bags deflating.
Tom
Tom,Pat and Buster the Boston Terrier
2004 Dutch Star 3807 Spartan 370HP
Jeep Grand Cherokee
RCtime
Rancho Palos Verdes, Ca.
Posted: 08/18/08 06:48am Link  |  Quote  |  Print  |  Notify Moderator
Head it into the wind, Close your vents up tight. I would not have it next to a tree, where falling branches would get it..
I was in a high wind in Galveston TX. 88mph recorded at the airport nearby.
Luckily the spot I was in faced the wind most of the time. The plastic roof vents rattled no matter how tight I had them. It rocked and rolled. I did not have levelers on that coach.
Ron
2002 34HD Winnebago Journey DL, Cat. 330
2004 Honda CRV - Garmin 2610
Great wife & Cavalier King Charles Spaniel
TT/N
1fastdad
mo.
Posted: 08/18/08 06:49am Link  |  Quote  |  Print  |  Notify Moderator
The best place to park it would be in another state but if you can't do that try to put it close to a strong building on the north side. Good Luck.
Fulltimingman
Livingston, TX, USA
Posted: 08/18/08 06:52am Link  |  Quote  |  Print  |  Notify Moderator
With 90 mph winds, the best thing to do is use your MH to get away from the area. Take a trip and get out of there. If you are parked parallel to the wind, 90 mph is strong enough to blow debris through the windshield. If you are parked perpendicular to the wind, you are in damage of debris going through the windows and gusts toppling your MH.
If you were talking about 50 mph winds I would say park with the rear of your coach to the storm, dump the suspension and put the jack down until they just touch the ground but do NOT lift the coach any.
With 90 mph winds, please leave.
Michael Day
Newell Coach
PT Cruiser Turbo
Patrick the Irish Wolfhound
Native Texans
trop-a-cal
Palm Coast Fl
Posted: 08/18/08 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Filling up fresh water tank can give you more stability as the weight will hold you anchored. Of course awning up as they can act as sails. Find the safe structure in your park to go to if the winds get to strong. Stow the patio furniture so it doesn't blow away.
chucl66
Milton, Florida
Posted: 08/18/08 06:55am Link  |  Quote  |  Print  |  Notify Moderator
How about in a campground in AZ.Into the wind, if you have a place that would break the wind, near it.
Good luck!
Chuck
Pensacola FL
how
Chuck & Laraine
dentmac
Southern Ontario, Canada
Posted: 08/18/08 07:01am Link  |  Quote  |  Print  |  Notify Moderator
On the north side?
If Fay comes up the coast and passes just west of you as likely at this time. The winds will be East and then quickly swing through south and hit again from the West. Flooding is of concern if this westerly wind occurs at high tide.
Fortunately, Fay is not expected to be over a cat I at landfall.
Good site here http://www.nhc.noaa.gov/graphics_at1.shtml?5day?large#contents
read the "discussion"
* This post was edited 08/18/08 08:06am by dentmac *
Sully2
Cincinnati
Posted: 08/18/08 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Tom
Ever seen a horse or a mule in the field during a HARD rain, etc with high wind... RUMP FIRST. Point the windshield away from the oncoming wind
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
wayne_tw
South Dakota/Georgia
Posted: 08/18/08 07:33am Link  |  Quote  |  Print  |  Notify Moderator
If you really think you will get 90mph winds, then you should evacuate. Personal safety is tantamount to everything else. Get in that motor home and get to a safer place. There is nothing maucho about riding out the storm.
Don Don
Pleasant Grove, AL {Suburb of Birmingham}
Posted: 08/18/08 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Fill it up with all fluids, water, gas, etc. Put the jacks up not down, if it is a DP dump the bags. You want it as low as possibe to keep wind from underneath and to have a low center of gravity.
Page of 8
