RV.Net Open Roads Forum: Towing: Greasing the Equilizer and Ball
Search only in Towing
Open Roads Forum  >  Towing
 > Greasing the Equilizer and Ball
Kampfirekid
Northern Illinois
Posted: 08/18/08 07:38am Link  |  Quote  |  Print  |  Notify Moderator
So, I typically grease the ball, the trailer hitch (where ball goes), the surfaces where the WDH anti-sway plates rotate, and the L-brackets where the bars rest. The hitch is usually quiet. Unfortunately, the grease catches dust, sand, and grime, and becomes noisy, squeaky, and ratchety after a trip or two. What grease do you all use? Do you grease the same points? How often? I am just following my dealers recommendations, but it seems wrong. It's like greasing stabilizer jacks. The grease collects sand, and it kind of defeats the purpose.
2009 North Trail 31BHD
2008 Ford F-150 King Ranch Supercrew
Equalizer & Prodigy
Me, the DW, and the Two Rugrats
DarylD
Fridley, Minnesota
Posted: 08/18/08 07:49am Link  |  Quote  |  Print  |  Notify Moderator
I am not sure what you are currently using, but this is the stuff I purchased at the time I purchased our equal-i-zer system.
Mine still makes noise after a few trips even using this stuff, but I was told to use VERY LITTLE per application.
http://www.equalizerhitch.com/store/index.php?p=product&id=105&parent=8
Daryl and Sandy D.
2007 Jayco Jayflight 25RKS
Ford F150
Equal-i-zer Hitch - Prodigy Brake Controller
1mtnman
Colorado
Posted: 08/18/08 07:53am Link  |  Quote  |  Print  |  Notify Moderator
I use a Teflon grease and grease the points you have mentioned with the exception of the "L" brackets. I understand that greasing those points reduces the effectiveness of the hitch. I don't know or does anyone else as to what degree. I think the best rule is it makes noise, it's working correctly.
amxpress
Clayton, NC
Posted: 08/18/08 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Robert,
This is from the Equal-i-zer installation manual, see page 24:
http://www.equalizerhitch.com/pdf/equalizer_instructions.pdf
I also used the "special" grease from Equal-i-zer, in fact I have 1/2 a tube left over that you can have; don't need it with my fiver.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2008 Palamino Sabre 31RKTS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Travel in peace...leave the M-I-L at home.
Dick_B
Palos Heights, IL USA
Posted: 08/18/08 08:30am Link  |  Quote  |  Print  |  Notify Moderator
I use several layers of wax paper on the ball and have the L brackets with the nylon/teflon pads installed both of which eliminate the need for lube.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
campercajun
Central Texas Hill Country
Posted: 08/18/08 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I use a little jar of white Reese ball grease for my Reese Strait-Line trunnion bar hitch, and also use it VERY sparingly on the Dual-Cam sway control to prevent noise from binding. I don't really have any problems with dirt, etc., because I apply the grease VERY sparingly on the ball, hitch, and sway control every time I hitch up, then wipe them clean each time I unhitch with a clean blue paper towel from Sam's club, removing all grease and contamination. This doesn't take more than a minute, or at the most two, and the microscopic amount of grease left on the surfaces after cleaning them off helps prevent surface rust from forming on them, and the resulting noise it causes.
To illustrate how little grease I actually use, we camp about twice a month from March-November, I've had this tiny jar of grease for almost 7 years now, and only about 1/4 of it has been used. If you are getting a LOT of debris contamination, you may be using too much grease, and not cleaning it off after unhitching allows it to just keep building up.
An alternative would be to spray silicone lubricant on these parts (as I have on my stabilizing jacks), and once it's dry, it will lubricate but is not sticky and won't attract dirt. Or, as Dick B does, you can use wax paper for just a smidgeon of lubrication.
Both the Equal-I-Zer L-brackets/WD bars and the Reese Dual-Cam sway control surfaces should be lubricated VERY sparingly, if you do use lubricant on them, as this reduces the friction, and therefore, the effectiveness, of the sway control. The Reese Dual-Cam has a center detent position, and the tension on the WD bars either keeps the cams centered in the "saddles" in the ends of the bars, or forces them to return there with extra bar tension if the tongue of the trailer tries to move in either direction. I haven't experienced any adverse reaction by very lightly coating the Dual-Cam's surfaces, even with our 33' TT.
* This post was edited 08/18/08 11:32am by campercajun *
2003 GMC Sierra Crew HD; 6.0L; Prodigy
2006 Thor Tundra 30RL-DSL; Reese Strait-Line & Dual-cam HP
2001 Honda Elite Scooter
Jim & Gayle Bryant
Murphy's Law: "Anything that CAN happen, WILL."
Bryant's Law: "31 years of RVing? Probably already HAS."
AutoEngMike
Erie, PA
Posted: 08/20/08 10:47am Link  |  Quote  |  Print  |  Notify Moderator
I have used the Reese "ball-lube" on my equal-i-zer. I don't think it's much different than white grease. Works fine.
2003 Dodge Ram 1500 Quad, 4X4, 5.7L Hemi, 3:55 gears
2005 Honda PilotEX (wife's)
2006 Rockwood Roo 23SS, 6500lb GVWR, Prodigy Brake Controller, and Equalizer 1K WDH
http://community.webshots.com/user/AutoEngMike
Mike Schriber
San Diego, CA
Posted: 08/20/08 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
I use the Reese Ball Lube on my Equal-i-zer as well. A bunch on the ball and a bit on the sockets for the bars. I don't put anything on the L brackets... I want as much friction there as possible.
Mike
2005 Chevrolet Suburban K2500 LT (8.1 liter with 4.10 gears)
2004 Starcraft Homestead 29BHS (16,000 pounds combined)
Twin Honda EU2000i Generators - 12' Porta-Bote
Prodigy / Putnam XDR / Equal-i-zer
SoCal Family Campers
