RV.Net Open Roads Forum: Tech Issues: TT Battery Charging System
 > TT Battery Charging System
OleMissTailgater
Corinth, MS
Posted: 08/18/08 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Hey Guys,
On our TT we have a converter and I am assuming that is what changes our power to DC and charges the battery. On most TT is there a fuse or a breaker you can shut off so that it will not charge the battery? The reason I ask this question is when my AC starts up and my converter is running it will make my generator surge up to high for the econ mode. If I am not using the correct wording please correct me. Thanks
2007 Keystone Summerland 267BH
bldrbuck
Boulder, Colorado
Posted: 08/18/08 09:48am Link  |  Quote  |  Print  |  Notify Moderator
I see nothing wrong with the generator going out of econ mode. In fact when I am using the air conditioner I switch it out of econ mode. There is a breaker that controls the input to the converter to find it disconnect the battery, turn on a 12 v light and flip breakers until the light goes out. If your converter has lights on it they should go out with out disconnecting the battery,
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
skipnchar
Topeka Kansas USA
Posted: 08/18/08 11:07am Link  |  Quote  |  Print  |  Notify Moderator
If you find an air conditioner that WON'T make the generator come out of ECON mode I'd be amazed. Your air conditioner is the largest draw you have on the trailer. It's not going to make any difference whether the charger is running or not.
OleMissTailgater
Corinth, MS
Posted: 08/18/08 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
If the AC the charging system is not running it will start in econ mode with no problem.
