RV.Net Open Roads Forum: Toy Haulers: Roadglide bottoming out
Search only in Toy Haulers
 > Roadglide bottoming out
kosko1
alaska
Posted: 08/18/08 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Bought a 07 New Vision to haul the Harley with. Went to load it yesterday and found that it bottoms out coming onto the garage floor. Any ideas to remedy this situation would be greatly appreciated. Thx
bldrbuck
Boulder, Colorado
Posted: 08/18/08 10:14am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like you may be overloaded or need new springs. Maybe longer spring shackles will help. What kind of approach go to the garage? Like a curb maybe? If your New Vision was bought used check with the previous owner.
Point Man11
Boston, MA
Maybe you've tried this but my first thought would be to raise the tongue of the trailer to make the rear end lower so there would be less of an angle where the garage meets the ramp door. My GF's Nightster will scrape on my Jayco if the pitch is too much, too.
Point Man11
2007 Jayco 26' Octane ZX TH
2002 Ford F-250 Lariat Supercab, 5.4 V-8
2005 H-D Electra Glide Vivid Black
2008 H-D Nightster 1200 Olive & Black Denim
2002 Honda Rancher 4X4
2002 Lund 1660, 25 Merc 4-Stroke
Boston, MA
dhamblet
Olympia, WA
Posted: 08/18/08 10:25am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like either:
1. Your trailer sits too high (has someone flipped the springs* on the trailer?) causing a severe angle at the hinge point of the ramp, or
2. the ground is lower behind your trailer where the ramp hits the ground, or
3. your bike is too low to clear the hinge point angle. Is the bike lowered?
Or a combination of the above.
* On most trailers the springs sit below the axles. but some are raised by setting the axles under the springs for greater ground clearance.
2005 Dutchmen 35SRV, Pergo floor, 5th Airborne, JT Strong Arm, Kodiak Disk Brakes, Backup camera
2006 Dodge CTD RAM QC 3500 LWB 4WD, Reese 16k, Airlift, Pacbrake, Britebox, 60g aux fuel tank
04 HD Ultra, CanAM 400MAX Quad
Spending my kids inheritance
Blackdiamond
So. Cal
Posted: 08/18/08 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Try placing a jack under the ramp and once you get the bike up to the point it scrapes, jack the ramp up to give the rear wheel more height, this along with what others have suggested should help.
07 Fleetwood Discovery 39S
07 Weekend Warrior SX1800
05 525 EXC
04 LTZ-250 and 04 CRF 230 for the wife, almost quad free!
04 TTR 90
03 XR 80
Hap Hazard
Mammoth Lakes
Posted: 08/18/08 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
Quick and easy fix. Place a 2X6x12" to 24" long piece of wood on the ramp door so the end is at the hinge line for the garage floor. Simply drive over the wood. It will raise the rear tire to clear the angle. If you still need additional clearance, add a 2X6X12" to the end of the prior piece nearest the door hinge.
To come out, simply lay the board down but make sure someone holds the end that's down the ramp, so it don't slide.
Hap
Chickie
Slatington,Pa USA
Posted: 08/18/08 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
Our trike does the same thing on some campsites and at home. I carry a 2x6 along with us and put in under the front wheel as I enter the garage. That would have to be before you enter the garage. I also don't sit on the trike. That gives me additional room. If you have air shocks try adding air to them before going in that will raise the bike some also.
Good Sam Life member
GWRRA member
NRA Life member
2002 F350 Lariat SC 4x4 PSD 6 speed,
2008 Goldwing GL 1800/2008 CSC trike conversion
2008 KZ Sportsmen Sportster 35'
Retired and loving it.
CrazyTed
Hoollieville #214
Posted: 08/18/08 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
We used to put some wood under the ramp and then use a small ramp to get up onto the RV ramp. That decreases the angle coming into the garage. Several companies make little ramps to use in this case. They are designed to getting lowered race cars into their race trailers.
CrazyTed
www.CrazyTed.us
Va Bch, VA
2006 KTM 450 XC
1997 Triumph Tiger 900
2005 Chevy 2500HD 4X4
2008 CrossRoads CrossTerrain TF36DS
