kat1958
Henderson, NV
My brother told me that using WD-40 on the tires helps to keep them from cracking. Is this true or will it damage the tires?
Kathy
2006 Ford F-150 Super Cab 5.4 Triton/3:73, Hensley TruControl Brake Controller, Ride Rite Air Bags, 2006 Sprinter 2991RLS, Hensley Arrow Hitch, Kipor 2000i, Xantrex RV2012, 1 Lovely Teenage daughter, who is now an U.S. Army Soldier, and 2 Crazy Dogs.
jplunkett
Virginia
I'm sure others will weigh in on this, but I do not see how this will help your tires, WD40 being a petroleum product combined with a solvent. I could see this getting on the the brakes and reducing stopping ability. It will probably make your tires shine with a 'wet' look like the tire dressings do.
safe travels,
John & Elizabeth Plunkett
Louisa, Virginia
BobJoh
Whitestown, IN 46075
Not WD40 but 303 protectant which is made for rubber. We use it on the leading edgesof aircraft on the rubber deicer boots. I was using WD40 on my ankle which has no cartlege after a motorcycle accident in '49. My doctor didn't like it, I now have done well with Gloucosomine/Chondritin aand no more pain.
edited 08/18/08 07:43pm by BobJoh *
BobJoh
LetsRV
Portland, OR.
WD40 is not a good thing to put on your tires. Yes, it will make them look black and clean for a short period of time. BUT, it will also dry them out and actually lead to failure (cracking) faster.
One of the best products for your tires is 303 Protectant. Enviromentally safe, and a great UV protectant. The suns UV rays are what are harmful to your tires.
We are all good at something.....
I just happen to be a good bad example.
Occasionally in error but never in doubt.
coolbreeze01
Redding, Ca
This is a perfect test. You use 303 or nothing and tell us how the WD40 works on your brothers tires. I use WD40 quite a bit, but not on my tires. Actually, I cover idle tires and don't put anything on the rest.
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
RobInAB
Edmonton, AB
I now use 303 where I used to use armorall years ago.Anything that is a petroleum product will cause deterioration. Use it on tires, window moldings(if you want) and all plastic bed rails and such on my truck.
Its a bit more expensive but I dont want my bedrails to fade as I have seen numerous times.
2007 Coachmen 24RBQ
2004 Ford F-150 FX4 SuperCrew (Traded)
2008 Ford F-250 Lariat Supercab PSD
thebat68
Spring Hill, FL
WD-40
Water Displacement - formula 40
If you're removing the water, you're drying out the tires.
Also, most people think that wd40 is lubricant, it is not, it is a cleaner (penetrant) that does leave a film behind that some can mistake as a lubricant.
2000 27' Fleetwood Prowler
2000 Ford Expedition 4WD Eddie Bauer
'91 & '95 daughers, '94 son.
RV'ing or Camping in one form or another all my life.
(Map is only with current TT)
Blind45
Largo, Florida
Have to agee with everyone. WD-40 is a petroleum base product and will do much more harm than good. I use 303 and am very happy with it.
Good Luck
04 Keystone Springdale 245RL
06 Ford F-250 PSD
Super Cab, Long Bed, 3.73 gears
Firestone Rite-Ride Air Bags
The 2 of us since 1972
Taz the Dalmatian
BurbMan
Long Island, NY
kat1958 wrote: My brother told me that using WD-40 on the tires helps to keep them from cracking.
The next thing he said was, "Hold my beer and watch this!"
MattyL
Pennsyltuckey
i thought WD 40 was actually a water based solvent, could be mistaken.
