RV.Net Open Roads Forum: Engine Drain Plug 's' on a Ford V10 (F53) 2003
 > Engine Drain Plug 's' on a Ford V10 (F53) 2003
dtyrrell
UK
Posted: 08/18/08 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
Does anyone know if there is a drain plug on the block for the Ford V10.
I'm changing coolant and would like to drain the block.
Many thanks,
Dorian.
(GBM Landau, UK based)
Home Skillet
Pearland Texas
Posted: 08/18/08 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Yes.
There should be one on each side, right below the exhaust manifolds.
Be sure to remove the coolant hoses on the oil cooler to drain that coolant.
System holds 27.9L (29.4 quarts).
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
dtyrrell
UK
Posted: 08/19/08 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Many thanks for the reply and info.
I'll keep you updated.
dtyrrell
UK
Posted: 08/20/08 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Home Skillet,
Found the plugs, the one on the drivers side (left side) was at the rear below the manifold (as you indicated), and was easy to remove.
But the right side (passenger) was in the middle behind the engine mounting.
I could not get anything in the undo this one, so I reverted to flushing several times and then draining the one side, including the oil cooler unit.
I ended up with some 5L of water left in the block.
I then added the correct amount of antifreeze (for 27.9L) and distilled water.
Ran the engine several times, with the heater full bore..... no air locks ... top up the water ....Job done.
Once again many thanks for all your help.
Home Skillet
Pearland Texas
Posted: 08/20/08 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
No worries.
You can't totally drain all the coolant anyway.
The way you did it is perfect.
ArchHoagland
Clovis, CA, USA
Posted: 08/20/08 11:50pm Link  |  Quote  |  Print  |  Notify Moderator
Curious what you did with the drained coolant?
Over here we aren't allowed to drain it into the storm sewer system.
It must be captured and taken to a disposal site.
Is your country the same?
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison transmission
6.9 MPG based on a 6,000 mile trip around the U.S.
US Gear Toad Brakes
dtyrrell
UK
Posted: 08/21/08 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Well, over here it not as strict, but I took mine to a friend who works in a garage to dispose of. The flushing water I lost down the sewer / fresh water systems!!!
