RV.Net Open Roads Forum: Tow Vehicles: How many miles on your sparkplugs?
Search only in Tow Vehicles
 > How many miles on your sparkplugs?
Page of 5
dodge guy
Chicago, western subs.
Posted: 08/19/08 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Perrysburg Dodgeboy wrote:
Kevin Dodge is the one that set the 100K plug change, note this is not using the extreme service schedule and for your TV that is the one you need to use. You should go be the book and if you don’t have the owner’s manual and maintenance schedule you can buy one on e-bay very cheap.
Don
HUH!
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
no_bytes
Wisconsin
Posted: 08/19/08 11:30am Link  |  Quote  |  Print  |  Notify Moderator
2000 F150 was 135,000 and that was just because I thought it was time, never had a problem with them.
SpoiledRotten
Central Mississippi
Posted: 08/19/08 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
I'm at 114,000 miles and have never changed a spark plug on my truck.
Just the 3 of us...SpoiledRotten, TotallyRotten, and ALittleRotten
2000 F-250 Lariat, CC
7.3 PSTD-Superchipped
2005 33RL2 New Vision - AKA "SpoiledRotten"
2000 Jeep Wrangler Sahara Edition
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 08/19/08 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry was not very clear here I was pointing out that plugs run for 100K under normal service. Kevin Dodge is the one that set the 100K plug change, note this is not using the extreme service schedule and for your TV that is the one you need to use.
was just showing here you can find cheap replacement owner's manuals, sorry for the confusion.
Don
HUH!
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
pics
ib516
Up here!
Posted: 08/19/08 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
I helped a friend change the plugs on his 2001 Dodge Caravan. Just a hair over 100,000 miles on them (originals). One measured 70 thousands (spec is ~40, all the rest were around 50 - 55. Quite worn, but the van still ran fine. This was a 3.3L V6. Plugs weren't that bad to change. Front 3 were very easy of course, back 3 - got two from drivers side, and the passenger side most one we got from the passenger side after I removed the MAF sensor and air intake boot between the filter housing and the throttle body.
Speaking of the throttle body, I sprayed some cleaner in there - it was really gummed up with varnish around the throttle butterfly.
2004 Cougar 301 BHS 6580# Dry, 9000# wet, 9600# GVWR)
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
Hypertech Max Energy
"MEGACASPER" 10100# GVWR, 5200# FGAWR, 6200# RGAWR
PICTURES
ELIM 3000 Gen (still going)
Collision Reconstructionist
ScanGauge2
dodge guy
Posted: 08/19/08 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Oh, OK! well I don`t go by the factory service schedule because I`m a tech. at a dealership. a CJD dealer actually, and I`ve seen what can happen when things aren`t done when they should be. most of the time they need to be done sooner. those manuf "recomended" maint. schedules in the book are just there to say " hey, buy this vehicle and you don`t need to do nothing for 100k"! it`s a sales thing. and knowing what I know, is why I tell everyone to do things sooner than what the book "recomends"
And I do have all the original manuals that came with my X.
AutoEngMike
Erie, PA
Posted: 08/20/08 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Every 30000 as recommended by Dodge, all 16 of them. At 128000 and still running strong after 4 changes.
2003 Dodge Ram 1500 Quad, 4X4, 5.7L Hemi, 3:55 gears
2005 Honda PilotEX (wife's)
2006 Rockwood Roo 23SS, 6500lb GVWR, Prodigy Brake Controller, and Equalizer 1K WDH
http://community.webshots.com/user/AutoEngMike
Campfire Time
Wisconsin
Posted: 08/20/08 11:49am Link  |  Quote  |  Print  |  Notify Moderator
98,000K on my truck right now. Original plugs. Runs fine, mileage is the same as when I bought it at 56k. I'll be changing them in the next month or so just because its a good idea.
Chuck D.
'03 Jayco Kiwi 17a, '03 Chevy Trailblazer EXT, Garmin Nuvi 200 GPS
Photography is my obsession: http://coldwater.smugmug.com/
“Adventure is just bad planning.” - Roald Amundsen
eightballsidepocket
San Jose, California, USA
Posted: 08/20/08 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
charwan wrote:
I've got everybody beat so far. 150,000 and no miss yet. That's on a 99 Ranger.
You might want to re-gap your plugs with 150k miles on them if they look nice and clean. I have a gut feeling your plug gaps are pretty big and over spec with that many miles. You might be surprised with a mileage increase and a little more engine pep by re-gapping them.
If you have aluminum heads, torque those plugs back in with a Torque wrench as you can easily strip-out plug holes by hand tightening without a torque wrench to set torque to spec.
Regards, Eightballsidepocket
2005 Dodge Ram 2500 SLT 4x2 Quad Cab, Cummins, 48RE Tranny, Lg Bed, Line-X Spray-on Bed Liner.
06 T25BS Komfort Trailblazer TT
"If you can't say it in person, it isn't worth saying while hiding behind an anonymous P.C.!"
BenK
SF BayArea
Posted: 08/20/08 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
note that with the wear and increased gap, there is more and more voltage needed
to 'jump' that larger gap.
This will wear out the components in the ignition system faster.
Like the coil(s), ignition wires and if dist, the rotor/cap.
If I have to touch my plugs in any vehicle, they get replaced.
Kinda sorta like one of the guys in our car club. Alpha and always bought
Michelin but he drove them till the steel belts showed and when sparks were seen
during the nite, he bought new tires...
-Ben Picture of my rig
Page of 5
