RV.Net Open Roads Forum: Fifth-Wheels: roof ladder strength
 > roof ladder strength
JFG
TN
Posted: 08/19/08 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Mine also says 300 lbs
Fred
mwebber78
New England
Posted: 08/19/08 09:59am Link  |  Quote  |  Print  |  Notify Moderator
At 6'3 250lbs I can tell you that the Atwood brand ladder I have on my previous and new camper both flex a bit, are narrow and not my favorite. However, they are sturdy enough to support me safely and use on a regular basis for roof inspection and cleaning.
I hate heights and trust the ladder so I guess that says something......I think....
Michael
2 DD's and my DW
6 Acre's of Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD Ext. Cab LT 4X4
Champion lil' yellow Chinese genset, 4000W
Camping Pictures
forte88
Hemet, CA
Posted: 08/19/08 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Mine says 300 pounds but I sent my 120 lb son up the ladder and watched the thing bowing, and the the screws bending. I refuse to use it.
2006 Keystone Challenger 32tkb
2001 Silverado 2500HD Vortec 8.1 ltr Allison Tranny
4.10 Mag Hytech diff
Vulcaneer
Northern New England
Posted: 08/19/08 10:36am Link  |  Quote  |  Print  |  Notify Moderator
If I have a choice I prefer to use a real ladder if I absolutely need to get up on the roof. I weigh 175#. I try my best to stay off the roof unless for a needed repair or twice a year inspection.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
CardMan
Saugerties, NY
Posted: 08/19/08 11:15am Link  |  Quote  |  Print  |  Notify Moderator
Same here, hate the heights... I know the ladders look weak but my worry all the time is how much can the roof really hold?
Once up there I don't feel very comfortable while I'm there... anyone have an answer to this?
TV: 2003 D2500HD 4X4 W/ HEMI - Timbrens, Prodigy, Reese 15k w/Slider, Line X
TT: 2004 Cardinal 31LX2BH
siliconjunkie
Buckhannon, WV
Posted: 08/19/08 11:45am Link  |  Quote  |  Print  |  Notify Moderator
I learned long ago, that folks my size (6'5" and close to 300 lbs) should never climb much of anything. They are never designed for us. I pay the dealer to play monkey.
RedRam
Moved from the smallest county in Texas
Posted: 08/19/08 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
I might climb up the ladder to look but i wont use it to get on the roof.If i need to get on the roof then i pull a real extendable ladder from underneath.
Fort_Turner
Sherburne, NY
Posted: 08/19/08 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Ours says 300# also. I climb 2x to clean the roof and once each trip before I pull in the slide. It has some flex but no more than some aluminum ladders I have used at home and at work. I weigh about 200#.
2006 Terry Quantium 2952BS 5'ver
2001 Dodge 2500 Quad Cab 4x4 LB V10
newk
Gillette, WY
Posted: 08/19/08 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
I weigh 250 and have never hesitated to use factory installed ladders to climb to the roofs of all my past RVs. Unfortunately my current 5er doesn't have a ladder, so it's the extension ladder for me now. I'm really getting too darned old for any climbing -- stairs are bad enough. Maybe my next unit will have an elevator to the top floor -- the penthouse patio.
Fiver-Get-You-Ten
Chattanooga, TN
Posted: 08/20/08 06:33am Link  |  Quote  |  Print  |  Notify Moderator
davelinde wrote:
Trailer Trash 2 wrote:
...there is no rating tag on any ladders put on trailers, and I know that OSHA would red tag every RV ladder
My ladder is stickered for 300# max - it's made of 1" tubing and the way it's attached that is pretty strong. As a general purpose ladder it might not meet OSHA standards I suppose - but it's a fixed ladder with a single use. For heavier loads I'd be most concerned about the attachment to the roof eventually working loose. However if you climb it "gently" that could be minimized.
Mine also has a rating sticker at 300#. Seems to be rather sturdy.
2007 DODGE RAM 2500 4x4 QC CTD 5.9 4SPD AUTO RIDE-RITES PRODIGY REESE 16K KWIK-SLIDE*** 2008 MONTANA 3400RL
