RV.Net Open Roads Forum: Travel Trailers: Help using black tank rinser
 > Help using black tank rinser
shadows4
Kansas City, Mo
Posted: 08/18/08 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
I was wondering what people do when the hose for rinsing the black tank has no fitting. Went to dump the tanks and found the fitting on the rinse hose had been cut off. Anyone else seen this before? Got any solutions? Thanks, John
2000 4X4 Excursion Limited 6.8V10, 4.30, 122,000 miles
Hellwig Rear Sway Bar
Roadmaster Active Suspension
2004 4X4 Expedition 5.4V8, 3.73 210,000 miles
2000 Coachmen 297 RKS
Reese Dual Cam Sway Control
Prodigy Brake Control
dhamblet
Olympia, WA
Posted: 08/18/08 11:47pm Link  |  Quote  |  Print  |  Notify Moderator
You carry a couple of plastic barbed hose connectors, one 5/8 and 1 3/4" and use them to connect to a couple of short hose end pieces with ends on them that you carry. Also useful for filling fresh water tank when no threadded faucet is available.
2005 Dutchmen 35SRV, Pergo floor, 5th Airborne, JT Strong Arm, Kodiak Disk Brakes, Backup camera
2006 Dodge CTD RAM QC 3500 LWB 4WD, Reese 16k, Airlift, Pacbrake, Britebox, 60g aux fuel tank
04 HD Ultra, CanAM 400MAX Quad
Spending my kids inheritance
SteveRankin
Sequim, WA
Posted: 08/19/08 12:59am Link  |  Quote  |  Print  |  Notify Moderator
I think most of the dump station hoses I've seen have the fittings cut off. We carry a 25' grey hose specifically for flushing the black tank. Remove the dumb station hose from the faucet, connect our hose, flush the tank, swap hoses back, hit the road. A minor bother.
Steve & C. J.
"Gracie" the Rough Collie & "Bo'sun" the Bichon Frise
2009 Arctic Fox 29V
2005 Chevy 2500HD Duramax 4X4 Crewcab
Hensley Hitch
TruControl Brake Controller
Our Beaver Technical page
Wildlife rescue at the Northwest Raptor Center
webslave
Clearville, PA
Posted: 08/19/08 05:59am Link  |  Quote  |  Print  |  Notify Moderator
We always use our own hose. I've installed Tornado tank rinsers on both the gray and black tanks. When I installed the hose connections, I put them right next to the dump valve and put hose quick connects on each one along with a quick detach cap for them (I use the quick connects with the fresh water setup, too...). Our 25 foot gray hose has the quick connect mate and a 40 psi pressure regulator installed. While I'm getting the slinky on and start the dump, the DW swaps the hoses...by the time she's got them swapped, I'm ready to hook up the first Tornado. When done, while I'm packing the stuff up, she swaps the hoses back.
BTW, I use the 40 psi regulator on the gray hose to keep from blowing up the Tornado rinsers...I've found that many dump stations have way too much pressure on their rinse hoses; high pressure causes most of the "problems" that folks have had with the Tornado rinsers
Don
DW
3 Cats
2008 FunFinder X 210WBS
2008 Jeep Hemi Commander Limited
jplunkett
Virginia
Posted: 08/19/08 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Like others, I have a rinse hose that I will connect - remove the stub, which was just long enough to rinse any spillage down the drain. I think CG folks to this to help ensure that folks don't try to fill potable water tanks with the rinse water. Several dump stations I've used had warnings posted that the rinse water was not potable.
safe travels,
John & Elizabeth Plunkett
Louisa, Virginia
tvman44
Southwest Louisiana
Posted: 08/19/08 07:25am Link  |  Quote  |  Print  |  Notify Moderator
safe travels,
I have rarely seen a hose at a dump station that had a male fitting on the hose. I just swap it with a short gray water hose I carry and do my thing and swap back when finsh.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
bradyk
Calgary, Alberta
Posted: 08/19/08 08:41am Link  |  Quote  |  Print  |  Notify Moderator
If it is a regular hose just carry a spare 1/2 or 5/8 lawn fitting. If it is one of those smnaller rubber hoses I made a smnall one that works. Go to the compressor area of home depot etc. and get a connector that is 3/8 and 1/2 inch at other end. Clamp it on to a piece of hose then keep a spare clamp for clamping to the cut piece of hose. On the 1/2" home piece just put a regular fitting and voila. I made one for the in laws as well and he says he needs it all the time. Where we live they cut them off so the atv guys don't wash their unti. This tends to keep them away.
2001 Chevrolet 2500hd Silverado 4x4 6.0L/4.10 Diff
2005 KZ Outdoorsmen 2605PF
Champion 4000W Generator
Mom & Dad
Shadow Cat,Yugi Dog
16 Foot Aluminum Fishing boat
pmooney1
massachusetts
Posted: 08/19/08 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Exactly what we do.
2001 GMC Yukon 4x4 SLT
2007 Kodiak 30BHSL
shadows4
Kansas City, Mo
Posted: 08/19/08 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Where we go alot the hose looks like a 1/2 inch. Could you post a pic of what your talking about? The way I have been using the intank rinser is to hook a 50ft garden hose to fresh water supply and stretch it out to rinser. A real pain! Thanks, John
BarneyS
S.E. Lower Michigan
Posted: 08/19/08 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
Purchase a Water Thief.
Blue Water Thief
Green Water Thief
I carry two of them. One (green one) is for use at a freshwater hydrant. The other (blue one) is for use at dump stations.
They press on the hose or bib without any threads and allow you to put on your own hose. They have a graduated inside diameter that fits every situation I have come across.
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
