RV.Net Open Roads Forum: Happi Jacks?? Tell me all about them, please
 > Happi Jacks?? Tell me all about them, please
Mrs. Mik
Abbotsford, Wisconsin
Posted: 08/19/08 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
What can you tell me about them? Would be replacing Ryco hand-crank jacks on a 1992 Lance with the electric Happi Jacks.
I'm asking for someone else, so I don't have any other information. Thanks for your help!
Julie
RV.Net Rallies: 17
Mik Blog
Mik Photo Album
BradW
Flat Rock, Alabama
Posted: 08/19/08 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Have you considered other brands of camper jacks? Most Lance campers come with Atwood jacks. There is also Reico-Titan jacks.
Caution: Possibel defective spelling above; spell checker is DOA.
Our Truck Camper Photos
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Visit the RV.net Blogs
Beddows
Abbotsford, Canada
Posted: 08/19/08 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
It's probably more likely the existing brackets would be compatible with Reico electrics since they are the same manufacturer. The cost is about the same as happijac. Both are comparable. I have reicos, so I could measure the holes for you, I am sure someone else here could do likewise for Happijacs.
2004 Chevy 3500 Duramax DRW
2008 Snow River Prestige Signature Edition. (The first, and maybe last of its kind)
jjohnson1179
Girdletree, Maryland
Posted: 08/19/08 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
I went from atwoods hand cranks to happi jack electric. I changed the brackets (when you buy the jacks as a compleate set it comes with all the mounting hardware and brackets) This was the best move I have done to a T/C The H/J lift the camper alot higher then the other jacks do as well I like mine and would not trade them for nothing O and I have a 87 lance 980 as well
JIMMY JOHNSON
93 Ford F-250 V8 5.8
1987 LANCE 980 11.3
AMSA# 52
TRUCK CAMPER MAGAZINE
FEET IN THE SAND COLD BEER IN MY HAND
Beddows
Abbotsford, Canada
Posted: 08/19/08 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Big problem with replacing brackets is how they are anchored to the camper. If you have to drill new holes near existing ones, it may be an issue. If you do replace them use sikaflex underneath them. Sell the 5th wheel, Julie?
chrisnpat
Gurnee,Il
Posted: 08/19/08 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
I thought you were talking about the Jacks we used to play with when we were kids, you know the kind with the little ball.
Christine
www.AnySoldier.com
canusa
hanwell, new brunswick, canada
Posted: 08/19/08 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
My experience with Happijacs has not been a good one. I got mine new on the camper in 2001--and they are manual not electric but the basic works are the same.
Mine were rusty on the outside white tube in a little over a year with absolutely no exposure to salt. The paint was lifting off in large flakes. The threaded rods inside the jack that allow them to move up and down also rusted although I followed the factory manual instructions for lubing and extending them. I ended up having to take them apart completely, derust, install grease fittings and then pack solid with grease to prevent further rust. I also found I got water penetration, perhaps wind driven, in the gear box under the plastic cap at the top of each jack. This is where the electric motor fits on the power models. I have caulked around the bottom edge of the caps to stop that.
I have not had the problem of the foot of the jack suddenly dropping and hitting the road with all the damage associated with that sort of thing. Thank goodness. Others have. A search here will get you those stories
A number of times I emailed and spoke with people at the factory. Although I was unfailingly patient and polite with them I got snarkey and insinuating answers back from the office staff. They may have been secretaries--I don't know. They were somewhat knowledgeable but what they seemed to know was that no problems came from design or manufacture--they all came from customer abuse of the product. You know,my 5 year old camper still looks like new inside and out. I just don't abuse my stuff. I maintain it. I certainly did not selectively abuse the jacks while taking good care of the rest. The only reason the jacks are still there at all is because I have done a whole lot of maintenance on them.
Now I understand ( but don't know) that they have a new owner. Things may be better--or at least different. I know some folks have had a good experience with the jack and the management. Personally I'd move to another brand when the time comes. Good luck to your friend with the search for a good jack
Cheers!
Herb
04 dodge cummins
03 northstar adventurer 8.5
reeeetired!!
wabbitman
Horsham, PA
Posted: 08/19/08 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Beware of the wired remote control. I had nothing but trouble with the rj11 connections. Finally, upgraded to the wireless remote and since then things have been great.
My two cents...your mileage may vary
wabbitman
Chevy Silverado 3500 HD ext cab 4x4
Vortec 6.0L V8 gasser
6 Speed HD Auto Trans
Z85 Handling/Trailering Package
HD Locking Differential
Bigfoot Truck Camper 25c10.4
Wife and Gary - Lab/Greyhound Mix
Days Camping in 2008 = 22
bigjimcruising
Orange County, CA
Posted: 08/19/08 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
There's a good reason they're known as "Crappijac's"!! Because they are!! Be prepared to risk loosing your rig or at least replacing them from time to time when they bend or otherwise fail. After owning them for a year and a half and already replacing jacks I'd say move on and buy something reliable. I'll switch as soon as I get enough cash to buy something else. Probably Atwoods. My advice: DON'T DO IT!
2007 F450 4x4 Extended Cab, 6.0 PSD AT, 9ft Flatbed with 8ft boxes. Okanagan 117DBL, loaded. 13ft tall! Happy Trails!
pjay9
Tacoma, WA
Posted: 08/19/08 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
I have Atwoods on my Lances. My 1997 had electirc and the 2005 has electric with remote...I LIKE THAT!!! The Atwoods worked wonderfully all those years and took some bad abuse every now and agin when i did something silly like backing in to far and sliding them along...OPPS!!! the sprung back, but forever a little off at the bottom as the bumper bracket got bent a tad..still worked just fine! Had that camper 11 years. @005 they work great witht the remote yet it is a bit touchy for final touch up levelinging...I am getting the hang of it! GET ATWOODS! Capt PJ
2005 Lance 1161/2004 Dodge CTD 3500 Dually
