RV.Net Open Roads Forum: Tech Issues: Removing Decals
 > Removing Decals
MFinCA
San Francisco Bay Area, CA
Posted: 08/19/08 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
The decal on the front of my TT is peeling and becoming faded. The ones on the sides and the rear are just fine.
I saw my RV dealer putting a new one on my same model for a customer and asked how much to replace it. $400 for the decal (special factory order)
What is the best way to remove the decal?
MFinCA
2004 Homestead Settler 255RS
1999 Chevrolet Suburban 2500
2RVers
Posted: 08/19/08 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
You can buy stuff to remove decals, probably a good place to look would be an auto paint shop. There is also an air riven tool that will scrape the decals off with no damage.
Rob and Jet
2000 Ford F550 with custom bed
1998 Jayco Designer 3710 fifthwheel
Fred and Barney de Katz
jauguston
Bellingham, WA
Posted: 08/19/08 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Go to a auto parts store and ask for a decal eraser. It is a wheel made out of eraser type material that you put in a drill. Not easy but by far the easiest way. Were it me I would remove the old decal and have the dealer install the new one. Let them assume the possibility of screwing it up.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 08/19/08 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Forget the $400.00 new decal, you can have it painted on at any sign shop for the same or less, cusomize it to fit you, and it won't peel off and with the right paint, it won't fade either! You should be able on a warm day, peel the old stuff off with the help of a heat gun and/or denatured alcohol. If you do go with a new decal. keep it and the other decals wiped down with 303 Aerospace, it was designed for aircraft paint and graphics to keep them from UV and age damage. Works so well that none of my decals have ever shrunk, peeled or faded in the Califonia sun!
wtravlr1
Palm Harbor, Flordia, and Geneva-on-the-lake, Ohio
Posted: 08/19/08 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
You might try a hair drier. over the the decal.
there also this:
decal removal clicky
2007 Forest River Sierra 31fkd (37') dual slides
chevy suburban 2003 2500-8.1 L.4.10's
prodogy/reese dual cam
rollgard springs
Fulltiming it since 2004.
My Homepage and Rv pics press here
HubMonkey
Oklahoma
Posted: 08/19/08 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
A pressure washer will take it right off...
Hub
Roosting The Dunes Not Your Mothers ATV Site
#1TrojanFan
So Cal
Posted: 08/21/08 01:04am Link  |  Quote  |  Print  |  Notify Moderator
Best thing I have used to remove decals/sticky "crud" is 3M adhesive remover. It comes in a red can with white lettering. I think the part number is 08984. You should be able to find it at an auto paint store, maybe home depot.
 > Removing Decals
