RV.Net Open Roads Forum: Technology Corner: Windows XP pop-up adds
 > Windows XP pop-up adds
TankerDude
West of Middle Earth
Posted: 08/19/08 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Ok.
I'm finally tired enough of the BS from whatever moron wrote the code that has infected my machine.
I've been getting these full-screen pop-up windows for the last couple of days now. Seems about every four minutes or so ANOTHER add for some useless******is showing itself on my screen.
I've checked everything I know to check: pop-up blocker, ran AGV virus scan, Webroot Spy Sweeper, checked control panel settings, all to no avail.
Can someone PLEASE help me figure this out (and get rid of it) before I decide to throw my PC in the pool?????
2004 Ford F350 PSD 6L 4x4 Crew Cab.
2007 Jayco Eagle 322 FKS.
Camping with DW Terry,
Bobi-Sue and Billy-Joe,
Westhighland White Terriers
JFG
TN
Posted: 08/19/08 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried a system restore to a previous date under "Performance and Maintenance"
Fred
ReadyToGo
Minnesota
Posted: 08/19/08 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Well the problem is that one of the easiest way to get this problem is from clicking on an ad in the first place. Usually it is something like this: you see something on the screen that says your computer is running slow, click here to speed it up. Another one is to put something like a weather program that shows the weather every 15 minutes or so. A third is some game you may have bought that installs some extra stuff. If it is caused by some of the above, it might not be considered malware as you indicated you wanted part of the package. That means that the malware programs won't do anything about it. Unless you can pinpoint when they started happening and what you might have done at that time it can take quite a time to find it.
I would try something like Spybot Search and destroy as a starter as that will sometime find these types of programs. A-squared is another one. I have found that each of the malware programs find things that others don't find. Lots of luck.
jplunkett
Virginia
Posted: 08/19/08 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
You have the equivalent of a virus infection. This thing is difficult to eliminate - It will have hidden an installer in a protected directory - check the sysvol directory, which you will probably have to alter the security on to be able to open it - the reinstalls it if you find and delete the offending program. Once you find the reinstaller and kill it, you can start searching the registry for the entries that launch it. Last time I removed one from my brother's computers it took the better part of a day. Things like ZoneAlarm and hijackthis can help identify the culprit but the presumption is that you are comfortable noodling with them.
Hope this help a bit!
safe travels - road and cyber,
John & Elizabeth Plunkett
Louisa, Virginia
TankerDude
Posted: 08/19/08 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replys. I'm in the process of downloading Spybot S&D and A Squared right now. We'll see what happens and I'll post the results.
init6
Near Fredericksburg, VA
Posted: 08/19/08 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
The best thing to do is wipe and reload. Then you will be SURE you have gotten it and anything else that might not be showing signs that it is there. If your computer came with a restore disk. Backup your files and boot from that cd to wipe and reload the OS. Your machine will run like new again.
Just DON'T forget to back your files up before you do it.
2005 Pace Arrow 37c
Workhorse W-24 Chassis
chewbear
Lindenwold, NJ
Posted: 08/19/08 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
AOL IM is another good way for those ads.
New to Us
2002 Fleetwood Discovery
330 cat.
wtravlr1
Palm Harbor, Flordia, and Geneva-on-the-lake, Ohio
Posted: 08/19/08 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
another free program to help is
codestuff starter
it helps with slow starting, I use spy bot as well and AVG and they seem to have worked Codestuff is really nice it allows you to easily choose which programs will start. Make boot up much faster.
also
ccleaner clicky
its another freebee, but it will take out all cookies. But it cleans the register and makes it faster
ang
2007 Forest River Sierra 31fkd (37') dual slides
chevy suburban 2003 2500-8.1 L.4.10's
prodogy/reese dual cam
rollgard springs
Fulltiming it since 2004.
My Homepage and Rv pics press here
djncas
Waynesboro Pa.
Posted: 08/19/08 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
Your problem is you are infected with (Adware Virus) If you know what to look for you can find it,but if not here is what you need to do. First remove the spyware nproigram you have is is a port opener. Like opening the door for your cat to come in sure enough a fly will follow! Then Download AD-Aware by Lava Soft, http://www.lavasoft.com/
there is a free version but the AdAware plus is better Also download Avast home version its not as big as AVG but works better.
I have been installing both programs on my customers PC's and laptops for 8 years and know one has reported any problems. By the way I am a IT graduate for computers. doing system restore will only work until you connet to the internet, then you will have the sme problems. once you download AdAware and avast and have them both registerd. You must disable your internet conection so the programs can find the problems. Once they are found and deleted then reconnect to the internet and download from (Ashampoo) Win Optimiser (free for 30-45 days), this program will keep your system clean of errors and unwanted cookies and internet traces. If you decide to purchase Win Optimiser wait untill the last week of testing they will offer the program to you for yp to 45% off!
Good Luck
The journey of a thousand miles begins with a broken fan belt and leaky tire.
Carl and "D"
Drago the Rotten Rotty (Service Dog)
2007 4x4 Quad Cab Hemi Ram/ 2008 Keystone Hornet 26 RBS
lwmuddy
Murrells Inlet, SC
Posted: 08/20/08 03:12am Link  |  Quote  |  Print  |  Notify Moderator
Only use Firefox
With No Script, Adblock and disable your cookies unless you really need them.
Just because something says "Click Here" doesn't mean you have to.
