RV.Net Open Roads Forum: Travel Trailers: pink mold
 > pink mold
Pia
Canada
Posted: 08/19/08 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all, I've had my trailer parked at a site for the last 2 years in a shaded area and now most of the window rubber trim has pink and black mold on it and I cannot get it to budge off. Any ideas here?
jplunkett
Virginia
Posted: 08/19/08 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Did you try washing with a soap and bleach solution? Usually that will kill the mold and bleach most, if not all the stain, out? Also, is this inside or outside?
safe travels,
John & Elizabeth Plunkett
Louisa, Virginia
star6443
Buffalo, NY
Posted: 08/19/08 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Bleach is basically the only thing that will kill mold.
2005 Ram 2500 CTD Quad Cab
GMT
Chilliwack BC Canada
Posted: 08/19/08 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Greetings. Have had the same problem out here on the wet coast...I have used "Acetone" to clean the white rubber moulding. You can start with a damp or wet cloth and dab it with acetone, then go to full strength if needed. Seems to work. Hope it works for you.....
Grant.
Pia
Canada
Posted: 08/19/08 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Outside
egrove
Dallastown, PA
Posted: 08/19/08 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
The only way I got rid of it, and I tried a lot of ways, was to pull the molding off (not that hard), soak it in a bucket of water with bleach added for a few hours, pull it out (it will be pure white), and press it back in the channel around the window.
Eric Grove
Dallastown, PA
2006 Jayco Jay Feather 26S
2000 Toyota Tundra V8 4WD
View an online map showing campgrounds in the US
Add a Visited States Map to your signature
Hornet28BHDS
Parker, PA
Posted: 08/19/08 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Was it as easy to get back into the channel as it was to get out?
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
egrove
Dallastown, PA
Posted: 08/19/08 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, it pulled out very easily and I had no trouble pushing it back in the channel. I read this suggestion from someone else and was a little hesitant to pull it out at first, so I tried pulling a small piece out a little bit and then immediately pushing it back in before it was all the way out and saw that it would be easy. The trailer was a 99 Trail Lite.
doxiluvr
Tucson-AZ
Posted: 08/20/08 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Try "Comet Spray Gel - Mildew Stain Remover." You don't need to use much, it is amazing. We had specks of mildew under the awning and they disappeared within seconds. Then make sure you rinse with water and let dry.
Barb
2006 Keystone Sprinter 300fkms
2007 Silverado 2500 Duramax Diesel 6.6 - Allison 1000 6 spd. auto. tran.
1 high school sweetheart hubby - 1 longhaired mini-dachshund, Hannah
4 grown kids, 6 grandkids
1 2007 Yamaha v-Star 1300
Pia
Canada
Posted: 08/21/08 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, I did what you said and it worked beautifully. I love this forum.
Many responses within hours and lots of good info.
 > pink mold
