hackman63
rhode island
Hi, We're camping for the first time and are staying in Lake Tahoe we just learned that the nighttime temp. for the time we'll be there it will be mid to high 20's are there any special precaution's we have to take so that nothing freeze's etc...
Eycom
Fl to NY
If the plumbing is enclosed, just run the furnace at night. You can open cabinet doors to allow for warm air circulation around the pipes. Disconnect from the water pipe stand and run off the onboard water tank. Drain the FW hose and stow it away. I'm inclined to do the same thing with the sewer hose as it can freeze and crack.
Cooking, showering, and sleeping create a lot of condensation. Use exhaust fans while engaged in the first two and crack a vent or windows while getting some zzzz's.
You should be fine at those temps with the aforementioned precautions.
F-350 PSD/CC/DRW
Lance 1121-Nicely Appointed
burgess001
Springfield, MO USA
Cold weather strategy depends on your unit. However, mid to high 20's for a couple of hours should not be a problem as long as it was above freezing the day before, and will be the day after. I would fill my fresh water tank and stow the hose, but sewer and tanks should be OK, even if they are not enclosed.
Jerry and Katie
More than 20 great years motorhoming and still loving it...
2004 DSDP 3810 (more than I needed...less than I wanted)
2004 Trailblazer (too heavy but well worth dragging)
hackman63
rhode island
we have an 24' minnie and the day time temp's will be in the mid 60's so i think the pipes will be o.k. Thanks for the reply's
Bubby's RV
CA
We also have a 24-ft Minnie, have used it in those temperatures, and you'll be fine if you put the water hose away.
John, Winnebago Minnie 24V
rockylarson
Jersey Shore
Make sure someone brings along a hairdryer you can use if all else fails.
2 Retired
Myrtle Beach, SC
With day time temps well above freezing, you should have no problems. Agree about the water hose, but you can refill your house tank anytime during the day you need. Have a great time.
Two young retirees restless to GO!
Life is too short to wait too long to do all we want to do!!
Go and enjoy!!
