CW05 US ARMY
savannah georgia USA
Ok we had one of those awnings with the wind sensor on before moving to Las Vegas...we have had some really high winds and the think has not once rolled up on its own...we have it set at 12 mph winds...does anyone else have this problem
Terry (active duty army), Donna, Tya, Nathan, Trixie and whoever else decides to tag along
2006 38'BWQS SunnyBrook Titan (4 slides)
SCVJeff
Santa Clarita, CA.
There are at least two auto-retract awning manufacturers’ out there. I think you'll find that the majority of the users shut the sensors off because they're totally inaccurate or don't work at all. This is one of those things where there's nothing better than a human sensor.
Jeff - WA6EQU
Beach-House 4
Long Island,N.Y.
Just shut it off and push the button I did not get it with my power awning because of the same problems you are having.By the way did it ever work maybe they miswired it.
2007 KZ Montego Bay 30KSB3,B&W Companion Hitch,Prodigy BC,5th Airborne pinbox/2006 3500 DW D/A CC,Longbed,4x4.
Bumpyroad
Virginia
a "dumb" idea, sort of like designing a fantastic fan so it needs a rain sensor instead of just getting a MaxxAire to beging with.
bumpy
Warwagon
Graham, WA
I have the A & E auto awning w/wind sensor. The wind sensor part never has worked. I disabled the sensor part and just tie the awning down. Unless a rear guster comes down the valley.
Kevin
Warwagon
2Sooners
Oklahoma
We have had an A&E and now have a Carefree of Colorado -- both with wind sensors and both have worked great! If I were having the kind of problem you are having I would be bugging the dealer and the manufacturer for some help. More than once the wind sensor on each has saved my awning.
Get it checked out.
Foy & Lois Ann
2004 Monaco Safari Simba 30PDD
Demco KarKaddy SS Dolly
2006 Chevy Equinox toad
Matt & Carol
Fulltiming USA & Canada
If it's an A&E and never worked properly I would suspect that the DIP switches in the control box were never set correctly right from the factory. The RV manufacturer doesn't check them and a lot of times the dealer doesn't know how to. A&E can provide you with the switch settings or Google it and you will find the information.
Teton Frontier/FL 60
seniorEM
N/E Ohio
I have to say I have the Carefree electric with wind sensor and mine works like it should but I am not that trusting when it is gusting out I sometimes let my finger do the retracting
MCrankyPants
Dayton OH USA
Mine is the opposite...WAY too sensitive no matter how I set the switches.
2007 Teton Experience Sunrise pulled by 2003 Dodge 3500 Cummins HO 6-spd. 4x4
'61 VW Double-Cab
netjam
Varies
Add one more to the list of frustrated consumers who just turned the wind sensor off. Mine's an A&E. I just put it out when I want it and put it in when it needs to come in. Wind sensor is a neat idea in theory but it doesn't work on mine.
