takeakidcamping
Tallassee,Alabama
On a 2004 Cardinal 5th wheel,how do you adjust the hydraulic cylinder shaft on the slide outs?On the end of the shaft the nuts are not tight on the bracket.
skip298
South Bruce Peninsula Ontario Canada
That is "slack" and is there for a reason....unless the slide is not opening or closing(sealing) properly do not adjust those nuts!! I have seen the situation and asked the same question..I am repeating what I was told....get a qualified person to give you the answer and to the adjustment if neeeded...My own experience was,, finding the nuts on cylinder end loose.....that side has to be tight...
wittmeba
Roanoke, Va
Quote: how do you adjust the hydraulic cylinder shaft on the slide outs?
What are you trying to adjust or correct? Is there some problem?
Bruce & Carolyn Wittmeier
Viet Nam Vet 1968-69
I was born in Great Falls, Mt. My parents moved when I was 5.
I found them when I was 10 - they were in California.
takeakidcamping
Tallassee,Alabama
The slide in the bedroom does not go in straight.It moves from side to side.
donn0128
Pronounced Ore-gun
Have you actually lubricated the slide mechanism?
Donn
raygreg
Seattle,WA
skip 298 is correct........
darwinbeneII
NE Colorado
I am also interested in how to adjust slides. I have a 2006 Gulf Steam "Prarie Schooner" 29FWB. I have tried to get dealership to adjust and get them to close evenly. Thier answer was to spray silcone lubricant on the seals to no avail. This was done in the 1 year warranty period. So now I am having to do this myself.
Both slides are off about an inch of closing all the way and looke to be closed askewed. They don't leak and maybe should leave well enough alone. Any suggestions?
takeakidcamping
Tallassee,Alabama
Yes,I have lubed them.
wittmeba
Roanoke, Va
If your slide does not go in and out parallel to the side of the rig, you need to check your gears that keep both sides of your slideout moving together.
Hydraulic slides requires this as they have no other way to move both sides equally. The hydraulic cylinder/pump only provides the horsepower to do the work. The long bar with gears on each end keep it parallel.
edited 08/20/08 12:54pm by wittmeba *
