patlewis
Idaho
I am sanitizing my fresh water tank and need to drain 50 gallons of water with approx, 3/4 cup of bleach mixed. Can I just do this on my lawn? Seems harmless enough, but my wife isn't harmless if I am wrong and it kills the grass!
2002 Chevy Silverado 2500HD, Duramax, 15k Superglide, 2007 36' Forest River Sandpiper
Alberta-NewMexico
Calgary
patlewis wrote: I am sanitizing my fresh water tank and need to drain 50 gallons of water with approx, 3/4 cup of bleach mixed. Can I just do this on my lawn? Seems harmless enough, but my wife isn't harmless if I am wrong and it kills the grass!
At that ratio you are looking at about 0.01% concentration of bleach, while I wouldn't drink this water it will be absorbed over several square feet of lawn which would again reduce the concentration. I do this each year and have never noticed any change in the lawn appearance. If you have any concerns just put the sprinkler on before or afterwards for a few minutes to further dilute the bleach.
2006 Dodge 2500 Ram Cummins Turbo Diesel
2007 Pacific Coachworks Tango BHSS 2790
Dennis Bham
Alabama
IMO bleach at that low concentration will not hurt your grass ...
It is common to use bleach solutions when pressure washing houses and also when treating yards against parvo virus (I used to raise dachshunds) ...
Dennis
'08 Chevy 2500HD Duramax 4x4, Crew Cab, Std Bed e/w 18K Superglide
'08 Cougar 292RKS, e/w 16" Sendel wheels & BFG Commercial TA tires
PressurePro TPMS
davidj54
South Alabama
At that low a concentration I wouldn't worry about it at all. Go ahead and dump it on the ground it won't hurt a thing.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
pammi
Westland, MI
Glad to see you posting Pat. How's it going with the new 5er?
2004 Rockwood Roo 23B (new to us)
2006 Nissan Xterra
When we camp, it's DH & me mostly. Occasionally step-daughter (16) comes, though not necessarily her choice
beemerphile1
NE Ohio
Won't hurt your grass but one time I killed a large number of worms. They initially crawled out of the ground like they do when it rains hard but they were all dead a day later.
Tim
"Okay, I admit it, the only thing I'm really good at is being me."
Support the "No Child Left Inside Act"
2006 Weekend Warrior FK1900
1998 Ford E150 4.6L
1996 BMW R1100GS
2005 Trek Madone 9spd.
1995 Burley tandem
tvman44
Southwest Louisiana
That weak of a solution will not hurt anything and if you are still concerned add some more water to dilute even more.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Hornet28BHDS
Parker, PA
If you're using that small amount of bleach, I wouldn't worry about killing the grass.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Great-Dane
Antioch, CA
I use bleach to clean my dog run area at home (20 yrs Danes and Beagles).. Pure and straight and it always comes in contact with lawn 100% and its never harmed any blade of grass, or plant..
After is soaks in a bit its watered down with hose to remove the smell.. Only way to remove the urine smell from soiled ground. If pure bleach doesn't kill it, your mix won't hurt a thing..
-Bob
2004 SouthWind 32VS
eltejano1
Woodville, Texas
I am a retired house painter. We washed-down houses with STRONG Clorox solutions (sometimes a quart to 2 gals of water for stubborn mildew) right over delicate flowers and ornamentals and never had a problem. Shrubbery we ignored, but we would rinse-of delicate looking plants with clean water afterwards. It definitely won't hurt grass!
Jack
