RV.Net Open Roads Forum: Tow Vehicles: SYNTHETIC OIL FOR DIESEL
Search only in Tow Vehicles
 > SYNTHETIC OIL FOR DIESEL
BoiseRob
Boise Idaho
Posted: 08/20/08 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
I switched my '07 Duramax to synthetic oil at 10k miles. I did the "Old School" break-in period. Now I only use Schaeffer oil nose to tail. Schaeffer's has also improved my fuel mileage. I get 19-21 on the highway when empty and 13-15 towing my TT. Happy trails...
BoiseRob
roosky01
Lodi, WI
Posted: 08/20/08 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
mr. ed wrote:
roosky01 wrote:
IMHO, if you can swing it, put synthetics in your baby from bumper to bumper, even the blinker fluid...
I checked with the local NAPA store and they didn't stock any "blinker fluid". I assume this is the lubricant that goes in the turn signals. Is that correct?
My NAPA store stocks it between the flux capacitor bulbs and that new machine that rotates the air in your tires...
2008 Challenger 30TRL 5th wheel
2005 Chevy 2500HD CC/SB 4x4 Duramax (with some goodies )
2008 John Deere 850D XUV Gator 4x4 Diesel
Lipets
NY
Posted: 08/21/08 05:37am Link  |  Quote  |  Print  |  Notify Moderator
If you want to look at something different look at the Corvettes they insist on Synthetic and If I recall do oil changes at 10K.
Several other high performace cars come from the factory with it.
When I had my Ford 7.3 it had 90K when I bought it, I went to "the diesel forum" scouting around on switching to syn, everybody said no if you switch on an older engine the syn will loosen up many of the oil deposits around gaskets due to it's cleansing properties and oil leaks will likely develop. So I stuck with Rottella for another 100K changing out every 3K. Their consensus was the switch s/b done before 25-35K.
On my new 8.1 yes it's gas but a big block, I dropped the oil at 2500 and switched, I change out at 7500-8000 all is good.
I think if you coat a small metal part with Syn Vs. dino and try to pick it up you'll feel the difference.
Cost, about $5 v $2-3, divide that cost differential over 7500 miles on a per mile basis and it amounts to paying a penny or two more or less than fuel.
Bob
'77 Airstream Sovereign Intl 31' CB
WBCCI 11411
'07 GMC 2500HD 8.1
Wingnusa
Scott and Brenda Albuquerque, NM
Posted: 08/21/08 06:18am Link  |  Quote  |  Print  |  Notify Moderator
Having just switched from dino to Rotella synthetic(5w40?) I picked up 1 1/2 mpg empty and 1 mpg towing. The temp guage used to move around a little in the mountains but didn't this last trip. I buy all my filters on dieselplace.com and the oil at Wallyworld and take it to the dealer for a $15 oil change and lube. I'll be switching the tranny in about 3k miles to syn also. Is it worth it??? I think so but you'll have to decide. I've always used the GM computer for my oil changes (7-9k miles) and still will. Good luck!
Scott and Brenda Schnelle
Olivia and Jasmine, Mini Schnauzers
2006 KZ Escalade 36CKB
2006 GMC 3500 D/A(LLY), CC, LB
Fulltimer Class of '06
Lifetime Good Sam's members
Lifetime NRA member
USCCA Member
Amateur Treasure Hunter
Amateur Banjo Player
Greentow
Dover, DE 19904
Posted: 08/21/08 06:41am Link  |  Quote  |  Print  |  Notify Moderator
I use syn 'cause that's what it came with new. Amsoil in all of it.
Lee
2004.5 Dodge 3500 DRW QC, 4x4 LB, CTD 600 ,auto,4.10 , Prodigy, 05 Cedar Creek 36 RLTS w/ lots of bells & whistles .Honda 3000 genset. Mrs Greentow & Missy, Shih Tzu with an attitude. USA(R). 30+ years in the Fire/EMS service. CCRVC #29, GS Life member
vonzoog
Delaware
Posted: 08/21/08 09:47am Link  |  Quote  |  Print  |  Notify Moderator
There are two reasons that I use synthetic oil.
1st, in cold weather a diesel with synthetic will crank over much easier compare to the same engine running dino oil.
2nd, synthetic has a higher point at which the oil will burn. You may never reach this extreme high temperature point with normal use of your TV. What I like it for is if I get in a hurry and don't do a proper cool down after hard running (3-5 minute idle time), I believe the synthetic will protect the turbo charger much better than dino oil. Most turbo failure comes from frying the oil in the bearings before they have cooled down.
Another note is that synthetic will hold its viscosity longer than dino oil. This will be more of a factor of your maintenance schedule of oil changes. So the use of synthetic still comes down more to your type of driving and use of the motor. This is where the cost factor comes in and it becomes a personal choice.
For what it's worth, I use synthetic in all three (car/gas, SUV/gas & truck/diesel) of my vehicles plus lawn mower (larger commercial type), generator, and pressure washer. It makes me feel good.
If you have to ask why I drive a Diesel, then you will never understand.
2004 RAM 2500 SLT Quad Cab 4x4
Cummins(305/355) 48RE Auto 11.5 Rear
2004 Laredo 29GR
TWhaylen
Colorado
Posted: 08/21/08 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
BBAHHAHAAHAAH...I am always out of blinker fluid so I just stopped using my blinker all together.
2005 Surveyor SV234
2004 F-150 Supercrew Lariat w/5.4L/3.73 Gears
Voyager Brake Controller
Reese Friction Sway Bar
kghenson
Akron, Ohio
Posted: 08/21/08 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
There is no harm in using synthetic oil, just no real benefit. These threads are full of junk science and just plain foolishness.
#1. There is NO reason anymore to wait to change to synthetics, heck some cars come with it from the factory. Just and old wives tale from the early days of Mobile One
#2. You cannot extend oil change intervals because you switch to synthetic oil. Both oils far outlast the change intervals, you change it because it gets dirty. The reason we can keep oil in our vehicles longer now-a-days is that engines run a lot cleaner.
#3. Folks that use synthetic oil and test it to use it longer could just as easily do that with dino oil. Industry does it all the time.
#4 The folks who swear by synthetic oil are not bad people, they just want to feel they are doing something to protect thier baby. I use only synthetic in my Harley. No logical reason, just feels better.
Ken
08 Ford F250 SuperCab Lariet LB 4x4 6.4L Powerstroke
04 299RLS Sprinter
07 Ultra Glide Harley
00 BMW 540I Maroon
Friend of Bill Wilson
webecreekin
Las Cruces, NM 88005
Posted: 08/21/08 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
I thought that the Allison transmission came with synthetic. Isn't Dextron 6 synthetic?
2006 Chevrolet Silverado 3500 DRW Crew Cab--Duramax/Allison
2004 Cedar Creek 34RLBS
no_bytes
Wisconsin
Posted: 08/21/08 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Is there CJ-4 compliant oil that is NOT synthetic? My internets search only comes up with Mobil 1, Rotella and AMSOil.
